[AG-TECH] Gnome launchers in FC2
    Michael Miller
    mimiller at ncsa.uiuc.edu
    Wed Sep 15 12:02:20 CDT 2004
Jim,
Use gnome-session-properties to set up a "Startup Application".  I just
entered AGServiceManager.py  in the command box and logged out/logged in
and it works.
Michael Miller
NCSA
At 03:36 PM 9/14/2004, Jim Miller wrote:
>I am having problems with the launchers in Gnome.  If I open an xterm or a
>gnome-terminal and run Service Manager by physically typing
>AGServiceManager.py everything works fine.  However, If I try to run
>servicemanager from the menu items or create a launcher myself, the
>AGServiceManager will run and listen on port 11000, but as soon as the
>VenueClient tries to communicate with the ServiceManager, the terminal
>window disappears and the AGServiceManager.py script dies.  I have tried
>creating Gnome application launchers for the AGServiceManager.py script as
>well as created a launcher to run just a basic xterm that runs
>AGServiceManager (xterm -e AGServiceManager.py)
>I get the same result for both.
>Any Ideas?
>Thanks,
>Jim
Thanx,
Michael Miller
System Engineer
Visualization Technology Support
Computing and Data Management
National Center for Supercomputing Applications
University of Illinois - UC
217-649-0747
"If you're clear in your vision and trust the people in your team with
clear objectives, they will invariably do their best to achieve everything
desired, and usually deliver everything you could have hoped for and even
more." -Paul Debevec
