[AG-TECH] what --insecure does, and what should it do?
Eric Olson
eolson at mcs.anl.gov
Tue Sep 14 12:46:51 CDT 2004
Hi Dave,
I get that error when I use "https" instead of "http" in the venueclient
when connecting to an insecure server. Try using http in the url to
connect to a server that was started with the --insecure option.
(if you don't get the tcpAttr error anymore, but then the connection is
refused, make sure your hostname and ip address resolve to each other or
set GLOBUS_HOSTNAME to your ip)
The insecure option isn't heavily supported or tested in the core toolkit,
but there's now a feature request in bugzilla to propose designing
selectable security protocols into the toolkit.
http://bugzilla.mcs.anl.gov/accessgrid/show_bug.cgi?id=1160
If anybody has interest in something like this being in the next version
of the toolkit, please vote for it in bugzilla and add any suggestions or
comments you might have.
Eric
On Tue, 14 Sep 2004, David G Mills wrote:
> When I run the VenueClient with the --insecure parameter the client
> launches fine, however, when I try to connect to a venue server the client
> doesn't connect and the debugging output shows AG crashing ad complaining
> about its own code. Here's what I get:
> Traceback (most recent call last):
> File "/usr/local/lib/python2.3/site-packages/AccessGrid/VenueClient.py",
> line 841, in EnterVenue
> self.__EnterVenue(URL)
> line 712, in __EnterVenue
> (venueState, self.privateId, self.streamDescList ) =
> self.__venueProxy.Enter( self.profile )
> File "/usr/local/lib/python2.3/site-packages/AccessGrid/Venue.py", line
> 3339, in Enter
> (r1, r2, r3) = self.proxy.Enter(profile)
> File "/usr/local/lib/python2.3/site-packages/SOAPpy/Client.py", line
> 465, in __call__
> return self.__r_call(*args, **kw)
> 487, in __r_call
> self.__hd, self.__ma)
> 359, in __call
> config = self.config)
> 160, in call
> r = GSIHTTP(real_addr, tcpAttr = config.tcpAttr)
> AttributeError: SOAPConfig instance has no attribute 'tcpAttr'
> this attribute simply doesn't exist with the '--insecure' flag passed on
> startup. However without '--insecure' the attribute exists and is always
> set to None. I think the problem is that it's thinking the venue
> server addr protocol is httpg, and thus is looking for this 'tcpAttr'
> attribute, in order to call GSIHTTP(real_addr, tcpAttr = confif.tcpAttr)
> [this is taking place withing SOAPpy.client.py]
> so, I'd like to know if someone can tell me where this attr.proto
> attribute is set, as it would appear its being set incorrectly and not
> taking the --insecure flag into account.
> Thanks,
> David.
