[AG-TECH] Best single machine node hardware ? ? ? ?
Randy Groves
randy.groves at boeing.com
Fri Sep 10 14:44:22 CDT 2004
On the more commodity front, we've had good success with Dell Dual Xeon
Precision workstations, with varying sets of capture and display cards,
depending on the situation.
Here's one configuration:
Dell Workstation 650:
Dual 2.8 GHz Xeon
2GB Memory
Quadro 4 NVidia 900XGL Dual-Head Video
2 - 210 Osprey Video Capture
SoundBlaster Live
Matrox g200 MMS Quad Video (PCI)
-randy
At 05:30 AM 9/10/2004, Osland, CD (Chris) wrote:
> > Behalf Of Deb Agarwal
> > I have heard several of you mention that you are running a single
> > machine AG node.
> > I am planning to upgrade the hardware for my node and want to
> > try running
> > my room based on a single machine. Does anyone have specs suitable
> > for a single machine node running Windows XP or RedHat 9.0
> > that can transmit
> > at least 2 videos, operate 1 audio, drive 4 displays, and
> > keep up with
> > the video streaming
> > in to a well attended meeting in a venue? Lets say up to 30 arriving
> > video feeds.
>Here's a repeat of the info I sent out a few weeks ago,
>with the name of the audio card manufacturer corrected
>(I got it wrong in the original e-mail).
>Ours are:
> twin 2.8 GHz Xeon on Supermicro motherboard (I think)
> 1 Gb memory
> Winnov Videum 4400 VO video capture (4 streams, one card)
> Matrox Parhelia 256 Mb display card (we only needed 2 main
> displays)
> onboard 100 Mbit ethernet
>Spot the non-information about sound. Here's the story.
>I got Echo Audio cards (stereo, balanced I/O) cards but when we
>enabled them, they played back for about half a second and
>then produced a lovely blue screen. Turns out their cards
>don't work with Xeon processors - the memory access mechanism
>is subtly different from Pentiums, and the Echo Audio cards work
>with Pentiums and Athlons, but not Xeons.
>In a panic (days to go before VERY high profile demo - UK
>Minister for Science!) I found that the onboard AC97 audio
>chipset actually was full duplex, so added a balanced-unbalanced
>interface (we use Sonifex, but any will do) and a couple of
>stereo mini-jack to twin phono leads and we were away.
>I have now found that E-Mu 1212m cards do support Xeons
>(including twin Xeons) and so, as they are cheaper than the
>bal-unbal interface and save 1U rack space, will try those in my
>next nodes.
>On the display front, we are about to try the Matrox QID which
>has, at long last, surfaced - 4 outputs from a single PCI-X or
>AGP slot.
>We haven't done any stress tests, but from experience with
>3 single processor 1400 MHz Athlons and much slower display
>card (Matrox G200 PCI) I would be very surprised if the above
>doesn't cruise along with 20-30 incoming video feeds.
>Hope that helps
>Cheers
>Chris
>____________________________________________________________________
>Chris Osland Office tel: +44 (0) 1235 446565
>Digital Media and Access Grid Medialab tel: +44 (0) 1235 446459
>BIT Department Access Grid room tel: +44 (0) 1235 445666
>e-mail: C.D.Osland at rl.ac.uk Fax: +44 (0) 1235 445597
>CCLRC Rutherford Appleton Laboratory (Bldg. R18)
>Chilton, DIDCOT, Oxon OX11 0QX, UK
>[The contents of this email are confidential and are for the use of
>the intended recipient only. If you are not the intended recipient
>do not take any action on it or show it to anyone else,
>but return this email to the sender and delete your copy of it.]
> > -----Original Message-----
> > Thanks for any help,
> > Deb
> > Deb Agarwal e-mail:DAAgarwal at lbl.gov
> > MS50B-2239 phone :(510)486-7078
> > Lawrence Berkeley National Lab URL: http://www-itg.lbl.gov/~deba
> > Berkeley, CA 94720
