[AG-TECH] Possible enhancement for Toolkit
    Ivan R. Judson
    judson at mcs.anl.gov
    Fri Sep 10 06:34:51 CDT 2004
However, for the AGTk the GLOBUS_HOSTNAME envrionment variable if set to the
valid name of one of your adapters (and it's valid for *only* one of your
adapters), effectively fixes this problem. The caveat being the routing
metrics which Bob sent email about how to adjust previously.
If this doesn't address the issue, I'm not sure that it can be addressed in
the near future.
I'm interested to know what "other problems" with SP2 you're referring to,
since I've been running SP2 (in one form or another since May). In fact,
just recently we have added functionality to the AGTk 2.3 final release that
will allow it to correctly configure the included firewall. Other than that,
I've been happy with it, and have had no problems. The new interfaces
provided are extremely useful.
--Ivan
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov
> [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Andrew Rowley
> Sent: Friday, September 10, 2004 4:37 AM
> To: ag-tech at mcs.anl.gov
> Subject: RE: [AG-TECH] Possible enhancement for Toolkit
> Hi,
> I have noticed problems with multiple adaptors in XP also -
> this has also appeared on the mailing list some time ago.
> With multiple network adaptors, Windows XP may or may not
> choose the correct adaptor for sending and receiving
> multicast packets - if you are lucky it does!  If like me you
> are not lucky, you must disable all but the adaptor that you
> want to use, otherwise you may not be able to use multicast
> correctly.  Microsoft have said that this is a bug in Windows
> XP and it is fixed with service pack 2 which I for one am not
> installing yet due to other problems with it.  It is also
> related to the fact that programs do not allow you to select
> the adaptor to bind to and therefore bind to the default
> adaptor which may or may not be the correct adaptor,
> depending on how lucky you are.
> So it is a valid point that you should be able to select the
> adaptor which AGTk binds to rather than leaving it up to
> luck, or being forced to disable all the other adaptors.  The
> main problem I can see with this is that you need to tell VIC
> and RAT to use this adaptor too - does anyone know how this
> can be done?
> (Note see http://support.microsoft.com/?kbid=827536 for
> details of the multicast problems in Windows XP)
> Andrew :)
> Access Grid Support Centre,
> SVE Group,
> Manchester Computing,
> Kilburn Building,
> University of Manchester,
> Oxford Road,
> Manchester,
> M13 9PL,
> UK
> Tel: +44(0)161-275 0615
> Email: Andrew.Rowley at man.ac.uk
> [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Ivan R. Judson
> Sent: 10 September 2004 03:01
> To: 'Randy Groves'; ag-tech at mcs.anl.gov
> The toolkit is already handling the case where the machine
> has multiple network adapters; indeed almost all laptops have
> both wireless and wired connections, mine which I use for
> development has the following:
> NetWork Card(s):           3 NIC(s) Installed.
>                            [01]: Intel(R) PRO/100 VE Network
> Connection
>                                  Connection Name: Fast Ethernet
>                                  Status:          Media disconnected
>                            [02]: Intel(R) PRO/Wireless 2100
> LAN 3B Mini PCI Adapter
>                                  Connection Name: Wireless
> Network Connection
>                                  DHCP Enabled:    Yes
>                                  DHCP Server:     10.0.1.65
>                                  IP address(es)
>                                  [01]: 10.0.1.17
>                            [03]: Cisco Systems VPN Adapter
>                                  Connection Name: MCS VPN
>                                  DHCP Enabled:    No
>                                  IP address(es)
>                                  [01]: 140.221.18.114
> Plus, add the vmware interfaces, MS's fancy ipv4/ipv6
> tunnels, teredo, et al and you'll find that on XP the toolkit
> is doing quite a good job of working in the face of *many*
> network interfaces ;)
> Here's my development desktop net interfaces:
> NetWork Card(s):           4 NIC(s) Installed.
>                            [01]: 3Com 3C920 Integrated Fast
> Ethernet Controller (3C905C-TX Compatible)
>                                  Connection Name: Wired
>                                  DHCP Enabled:    Yes
>                                  DHCP Server:     140.221.11.6
>                                  IP address(es)
>                                  [01]: 140.221.34.71
>                            [02]: VMware Virtual Ethernet
> Adapter for VMnet1
>                                  Connection Name: VMware
> Network Adapter
> VMnet1
>                            [03]: VMware Virtual Ethernet
> Adapter for VMnet8
> Network Adapter
> VMnet8
>                            [04]: 1394 Net Adapter
>                                  Connection Name: 1394 Connection 2
>                                  DHCP Enabled:    Yes
>                                  DHCP Server:     N/A
>                                  IP address(es)
> What kind of a feature are you looking for? What's the use
> case you're experiencing? What problem are you trying to solve?
> --Ivan
> > [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Randy Groves
> > Sent: Thursday, September 09, 2004 8:38 PM
> > Subject: [AG-TECH] Possible enhancement for Toolkit
> > My recent experience with the 'Microsoft TV/Video' network
> connection
> > brings to mind an enhancement.  It would be nice if, during the
> > install (and maybe accessible later via a python script), if the
> > Toolkit finds more than one network adaptor installed on
> the machine,
> > it would ask the installer which one it should use.  This
> would have
> > made it obvious in my case, but also would handle the case
> where there
> > REALLY is more than one network adaptor in a machine.  I know that
> > I've also seen a 1394 network adaptor installed on various machines
> > with FireWire adaptors.
> > I will enter this in Bugzilla if it sounds like a good idea.
> > -randy
