[AG-TECH] vic email address prompts
Paul Hatton
P.S.Hatton at bham.ac.uk
Fri Sep 3 08:11:29 CDT 2004
I have recently (a couple of days ago) installed the Access Grid
toolkit 2.2 on a windows 2000 and a windows XP machine. vic on both
machines prompt me for an email address every time I go into a venue
(I've only tried the default venue so far) as in the attached screen
grab. Despite what it says, I don't have any Software\Vic entry in
the registry on either machine. In both cases this is when logged on
as administrator. If I go into the venue as a non-administrator user
it doesn't pick up the rtpName, so this seems to be stored somewhere
that is only readable (let alone writeable) by administrator.
The is using the Video Service, having removed the VideoConsumer
service.
Any suggestions as to how I can get it to remember my email address?
Thanks
Paul Hatton
High Performance Computing and Visualisation Specialist
Information Services, Elms Road Computer Centre,
The University of Birmingham, Birmingham B15 2TT.
Ph: 0121-414-3994 Fax: 0121-414-3952
The following section of this message contains a file attachment
prepared for transmission using the Internet MIME message format.
If you are using Pegasus Mail, or any other MIME-compliant system,
you should be able to save it or view it from within your mailer.
If you cannot, please ask your system administrator for assistance.
---- File information -----------
File: vic.bmp
Date: 3 Sep 2004, 10:35
Type: BMP-image
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040903/0593924f/attachment.obj>
