[AG-TECH] BridgeServer
Thomas D. Uram
turam at mcs.anl.gov
Thu Sep 2 16:10:09 CDT 2004
Sorry if I wasn't clear. There is actually no change in this behavior
from 2.1.2. There is only a change in your venue configuration.
If you configure your venue to use static addressing, the bridges will
start the way you've seen them start before.
Tom
Jeremy Mann wrote:
> Thomas D. Uram said:
>>It looks like you recreated the venues without static addressing, so
>>there are no streams in the venue to bridge. If someone enters the
>>venue and wants to send audio or video, streams would be allocated and
>>the bridge server should start bridges for those streams. This is,
>>however, different than you worked previously. If you set up your
>>venues for static addressing, the bridges should get started when you
>>start the bridge server, as previously.
> I think I understand. The BridgeServer doesn't do anything until it
> detects audio/video streams from a client. Why the change from 2.1.2?
