[AG-TECH] Simple question.
    Thomas D. Uram
    turam at mcs.anl.gov
    Wed Sep  1 15:36:41 CDT 2004
In 2.1.2, the stream name was not handled correctly, so it didn't show
up on the incoming stream windows.
Jim Senechal wrote:
> Just getting my 2.1.2 running so I expect I am different.  What would be the
> method on that version?  Thanks
> Jim
> Jim Senechal, Digital Conference Specialist
> North Dakota State University
> Fargo, ND  58105
> Phone # (701)231-6247
> E-mail:  jim.senechal at ndsu.nodak.edu
> -----Original Message-----
> From: Thomas D. Uram [mailto:turam at mcs.anl.gov]
> Sent: Wednesday, September 01, 2004 3:30 PM
> To: Jim Senechal
> Cc: ag-tech at mcs.anl.gov
> Subject: Re: [AG-TECH] Simple question.
> Jim:
> As of 2.2, the stream name should appear in the title of the sending vic
> windows, and in the title of the per-stream windows ("on the wall").  In
> the latter case, the title is <ProfileName>(StreamName) (e.g.,
> NDSU(Audience)).
> Note that changes to the streamname parameter show up only after the
> producer vics have been stopped and started, since vic doesn't allow us
> an option to change that info on the fly.
> If you're not seeing the stream names show up this way, and you're using
> 2.2 or later, you should file a bug.
> Tom
> Jim Senechal wrote:
>>I know the answer will probably be way to easy and make me feel ashamed
> for
>>not finding it sooner, but, here goes.  I cannot find where to change the
>>name of your streams so that the window that shows up on the wall says
> what
>>the stream is, ex. NDSU Audience, NDSU Presenter, etc...  I used the
> manage
>>my node to change the stream name so that it shows up on the vic, but I
>>haven't found where to input the names for the display windows?  Thanks.
>>Jim
>>Fargo, ND  58105
