[AG-TECH] Testing my system
    Bob Riddle
    bdr at internet2.edu
    Fri Oct 15 18:29:37 CDT 2004
Patrick Johnson wrote:
> I'm building a room based node for a customer of mine.
> Do I need access to internet-2 in order to test my system?  How about
> to retrieve a certificate?
You need access to a network that supports 15-30 mbps of multicast
traffic - or you'll need to use a multicast tunnel that is located on a
multicast enabled network (AG Bridge, rcBridge). In order to "meet" with
others in the current AG community, you'll need access to a network that
peers with the networks that other AG nodes use - certainly access to
the Abilene backbone will get you connected to these folks
(http://abilene.internet2.edu/).
When you install the AG software, it will take you through a process to
"get" a certificate - first to make the request and then to retrieve the
certificate, after ANL has "granted" it.
> Thanks,
> Patrick
Bob Riddle (bdr at internet2.edu)    Technologist,Internet2
3025 Boardwalk, Suite 100         Ann Arbor, Michigan  48108
Business Phone: 734.913.4257      Fax Number:  734.913.4255
"Math illiteracy affects 7 out of every 5 people"
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20041015/e0e82739/attachment.htm>
