[AG-TECH] ANL Lobby bridge
Michael Braitmaier
braitmaier at hlrs.de
Tue Oct 12 07:49:27 CDT 2004
Hi Gilbert!
----- Original Message -----
From: "ORNELAS, GILBERT (JSC-DV3) (STU)" <gilbert.ornelas1 at jsc.nasa.gov>
To: "'Michael Braitmaier'" <braitmaier at hlrs.de>
Sent: Monday, October 11, 2004 6:17 PM
Subject: RE: [AG-TECH] ANL Lobby bridge
> Hi Michael,
> Thanks for your quick reply. Excuse me if my questions are a bit too
> simple,
> I am fairly new to the Access Grid community and I am just trying to get
> going:
> I am trying to install a PIG at my office computer. I successfully
> installed it already
> on my laptop, but in my office I've had no such luck. From what I've been
> reading, my problem is
> that I am behind a firewall at work and ports need to be opened. Before I
> go to the network people,
> I want to be sure what is it exactly that I need to ask them for, which I
> don't know yet. Maybe just
> "I need a port open that will enable me to do multicasting?".
Unfortunately I can't help you with this , as our multicast network is
completely open.
So I didn't had to bother any fw admin.
> Anyway. I am not sure I'm on the same page as you. Ex. I can't even
> connect to a venue from
> my AG-VenueClient and my AG-VenueClient does not show the File menu that
> you
> mention.
My mistake, it is labeled Venue. I attached a screen shoot where to find the
properties for AGT 2.3.
Besides I would advise you to use AGT 2.3 as there are a lot of bugfixes
since 2.1.2.
Especially when you use it under windows it is easy to install. Remove
previous versions first.
> Also, I don't
> Think I have a QuickBridge application, and thus the vv.dat file you
> talked
> about. Is this something
> I need for my PIG to work? Here is a little history of what I've done:
I attached that file to this e-mail.
> 1. install the software (activeSate Python 2.2,
> wxPython-2.4.0, AG 2.1.2)
> 2. request certificate
> 3. import certificate ("Preferences" => "Manage
> Certificates" => "View Pending Certificates" )
> 3. run Venue Client (thanks for clarifying that the
> pass
> phrase was just the password)
> 4. configure the venue client and stored configuration
> (here, I did not add the
> VideoProducerService since I don't have a camera yet. I
> only left the AudioService and the
> VideoConsumerService enabled)
> 5. type https://hobbes.mcs.anl.gov:9000/Venues/default
> and click on go, but then I get the message
> window "Can not enter venue" about not being able
> to connect.
Maybe try the following url first. This works most of the time for me:
https://vv2.mcs.anl.gov:9000/Venues/default
The new server should work too, but most ppl are still on the old one. Find
the new one at:
https://watts.mcs.anl.gov:9000/Venues/default
> Once again thanks for helping me out. I'll try to work it out. Won't
> keep
> bothering you with questions
> after this.
No problem, you are welcome.
> Gilbert
Michael
Dipl.-Inf. Michael Braitmaier
HLRS - Visualization / Video Conferencing
University of Stuttgart
Germany
Website: http://www.hlrs.de/organization/vis/people/braitmaier/
> -----Original Message-----
> From: Michael Braitmaier [mailto:braitmaier at hlrs.de]
> Sent: Monday, October 11, 2004 10:08 AM
> To: ORNELAS, GILBERT (JSC-DV3) (STU)
> Cc: ag-tech at mcs.anl.gov
> Subject: Re: [AG-TECH] ANL Lobby bridge
> Hi Gilbert!
> Basically you can just connect to the room you want the mc-address and
> ports
> from and once the AG-VenueClient connected you can view the address and
> ports by opening the venue properties in File->Properties
> This gives you the data for the mc-address for the room. The unicast port
> mapping to these multicast ports are bridge dependent and can be
> configured
> by the one running the bridge through the config file of the QuickBridge
> application. In our case we bridge our own room by mapping mc-ports
> 59922-59926 to the unicast ports 50096-50099. But as said, the unicast
> ports
> are a matter of configuration of the bridge.
> In generall I realized that it is helpful to open ports above 50000 up to
> 53000 (with some exceptions). This is the range where most unicast ports
> for
> multicast mapping are used. You should be able to also find that
> information
> in a file called vv.dat which accompanies the QuickBridge application used
> by the BridgeServer of AccessGrid.
> Hope this helps
> Michael
> Sent: Monday, October 11, 2004 4:40 PM
>> Hi Michael,
>> I have a quick question. I am also having firewall problems and I
>> need to talk to the admins so that they can open the appropriate
>> ports. My question is this: what are those appropriate ports or how do
>> I find out what
>> they are? Do I just ask them that I need them to open the appropriate
>> unicast-multicast ports or what?
>> Thanks. Hope my question was not too broad or anything like that.
>> Gilbert
>> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
>> Behalf
>> Of Michael Braitmaier
>> Sent: Monday, October 11, 2004 4:24 AM
>> To: ag-tech at mcs.anl.gov; jeremy at biochem.uthscsa.edu
>> Indeed we run a bridge for the ANL lobby unfortunately changes in our
>> firewall configuration has locked the ports used for unicast-multicast
>> mapping. We will take it down for the moment and see wether we can
>> convince our fw admins to open the appropriate ports.
>> Michael
>> Germany
>> From: "Jeremy Mann" <jeremy at biochem.uthscsa.edu>
>> To: <judson at mcs.anl.gov>
>> Cc: <ag-tech at mcs.anl.gov>
>> Sent: Friday, October 08, 2004 4:25 PM
>> Ivan R. Judson said:
>>> We don't bridge the lobby.
>> Oh, ok, that explains it. Thanks!
>> BTW, using the AG from home (RoadRunner cable) actually worked! But
>> the major disadvantage is the bandwidth. Has anybody considered
>> modifiying RAT for a greater compression codec?
>> Jeremy Mann
>> University of Texas Health Science Center
>> Bioinformatics Core Facility http://www.bioinformatics.uthscsa.edu
>> Phone: (210) 567-2672
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20041012/4e48d6ad/attachment.jpg>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20041012/4e48d6ad/attachment.obj>
