[AG-TECH] Re: Packing shared app?
Dioselin Gonzalez
dioselin at purdue.edu
Mon Oct 11 16:56:33 CDT 2004
Thank you all for your help! I just wanted to share my solution:
I created a file 'install.py' that uses the python built-in function
'execfile' to register the application with agpm. It then uses
shutil.copytree() to copy the subdirectories. A lot simpler than I thought.
Dioselín.-
Dioselin Gonzalez wrote:
>Hello AG,
>What do you recommend for making an installer for my shared application? This
>is my situation:
>My application consists of not only .py files but also other files and folders
>that contain images, icons, etc. If I use agpm.py, it will copy only the .py
>files to the corresponding folder. Tom mentioned that agpm is the standard
>installer, so how do I tell it to copy the other directories and files as well?
>Hope I'm explaining myself clearly.
>thanks!
>Dioselin.-
