[AG-TECH] Video Capture Card
Patrick Johnson
pjohnson at imsav.com
Fri Oct 8 12:48:08 CDT 2004
Yes, exactly. I'm looking for a video capture card with the 3.3V notch
(PCI-X compatible) that has available Redhat Linux drivers and is know
to work well with the AGN 2.x software.
What is a recommended?
Patrick
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
Behalf Of Douglas Kosovic
Sent: Thursday, October 07, 2004 6:28 PM
To: ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] Video Capture Card
Hi Patrick,
> I recently purchased 4 Hauppauge WinTV Radio cards. They came with
> chipset 878 which has RedHat Linux drivers available. However,
chipset
> 878 has a PCI version that is incompatible with PCI-X. There is an
> option of getting Hauppauge cards with chipset 881 but I can't find
any
> RedHat Linux drivers.
I think what you are asking for is a PCI 3.3V/5V compatible capture
card, in
particular a PCI card with the 3.3V notch which will allow to plug into
PCI-X slot which only supports 3.3V. The WinTV Radio card you describe
sounds as if it only has the 5V notch.
The Bt878 based Pinnacle TV has a 3.3V notch, there are probably other
Bt878
based cards out there with the 3.3V notch.
Cheers,
Doug
