[AG-TECH] VenueVNC
    Douglas Kosovic
    douglask at itee.uq.edu.au
    Thu Oct  7 04:29:59 CDT 2004
Hi Randy,
>> Sorry, I feel a bit dense about this - I use VNC all the time, and
>> presumed that what I would be doing with the VenueVNC app was to start up
>> a viewer that I could point to an arbitrary venue server out there.  Is
>> this an
>> incorrect assumption?
> Yep, incorrect assumption, using the AGTk VenueClient GUI, you can only
> connect to a VenueVNC server, not an arbitary VNC server.
Sorry, my above comment didn't come out right and makes no sense. To clear
things up:
If you point a VenueVNC server at a URL on a venue server and the
VenueClient is using that same URL, then a VenueVNC entry will appear
under "Application Sessions" in the VenueClient. If you then open that
VenueVNC entry, a VenueVNC client will start up
Cheers,
Doug
