[AG-TECH] RH EL 3 - VenueServer Issue
Todd Zimmerman
toddz at sfu.ca
Fri Nov 19 21:21:13 CST 2004
Ah... perfect - thanks.
Seems to be working great now with PyXML-0.8.3-1 built from Fedora Core
1 rpm source.
I'll be testing the venueserver over the next week or so before putting
it into production. I'll keep you up to date on any issues encountered.
Thanks again,
Todd
Douglas Kosovic wrote:
> Hi Todd,
>> I'm having an issue trying to get a VenueServer to run on Red Hat
>> Enterprise 3.
>> Venueclient seems to operate fine (although I haven't tried with a
>> service manager...) but the VenueServer has the traceback below when
>> launched.
>> File "/usr/lib/python2.2/site-packages/_xmlplus/dom/minidom.py",
>> line 817, in createDocument
>> doctype.parentNode = doctype.ownerDocument = doc
>> AttributeError: 'str' object has no attribute 'parentNode'
> As that file is from the PyXML package, I suspect upgrading to
> PyXML-0.8.3-1.i386.rpm from the FC1 distribution will fix the problem. I
> can't confirm it at the moment, but someone previously on the list
> mentioned that on RH9 they installed PyXML-0.8.3-1.i386.rpm from FC1.
> If that's the case, I'll put a RPM dependency of PyXML >= 0.8.3, in
> AccessGrid-2.3-6.i386.rpm before it is released.
> Cheers,
> Doug
