[AG-TECH] Problems installing AG Toolkit 2.3
Andrew Rowley
Andrew.Rowley at manchester.ac.uk
Fri Nov 19 09:32:10 CST 2004
On a laptop, it is not necessary to run the node service or service manager
with AG2.3. Instead, just run the Venue Client. This will start your node
service for you. You can then use the "Preferences"-->"Manage My Node..."
to add the VideoProducerService (AudioService and VideoConsumerService are
usually loaded by default).
Andrew :)
Access Grid Support Centre,
RSS Group,
Manchester Computing,
Kilburn Building,
University of Manchester,
Oxford Road,
Manchester,
M13 9PL,
UK
Tel: +44(0)161-275 0685
Email: Andrew.Rowley at manchester.ac.uk
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf
Of Judy L. Cox
Sent: 19 November 2004 14:57
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] Problems installing AG Toolkit 2.3
Hello,
I installed AG Toolkit 2.3 on an IBM Thinkpad laptop (WindowsXP O/S) for a
customer. The video camera is Logitech QuickCam Orbit and the microphone is
Plantronics w/ echo canceling. I successfully installed the appropriate
software. In addition I requested and loaded the certificate. When I
tried to start the NODE or SERVER MANAGER services the following error
message appears:
NODE Service error message:
C:\Python23\lib\fcntl.py:7: DeprecationWarning: the FCNTL mode is
deprecated; please use fcntl.
C:\Python23\lib\termios:py:7: DeprecationWarning: the TERMIOS module is
deprecated; please use termios
Starting Node Service URL: https://my IP address:11000/NodeService
Starting Service Manager URL: https://my IP address:11000/ServiceManager
Traceback (most recent call last):
File C:\Program Files\AGTk-2.3\bin\AGServiceManager.py, line 145, in ?
File C:\Program Files\AGTk-2.3\bin\AGServiceManager.py, line 130, in
main
gNodeService.LoadDefaultConfig()
File C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py, line 359
in
LoadDefaultConfig
Raise Exception (Failed to load default configuration (%s) %
Exception: Failed to load default configuration (defaultWindows)
SERVICE MANAGE error message:
C:\Python23\lib\fcntl.py:7: DeprecationWarning: the FCNTL module is
C:\Python23\lib\termios.py:7: DeprecationWarning: the TERMIOS module is
Starting Service Manager URL: https://129.7.249.136:11000/ServiceManager
Of course, the service should be running before I can setup complete the
Node Wizard. I searched the internet for this error message and found an
article which stated the problem is due to Windoze which has a case
insensitive file system. I tried renaming FCNTL and TERMIOS. Also, I
renamed using the same name, but in lower case. Has anyone experiencing
this problem before? If so, what is the fix?
Thanks in advance for your reply.
Judy
