[AG-TECH] Building AG-2.3 for Mandrake 10.X
Eric Olson
eolson at mcs.anl.gov
Wed Nov 17 16:24:48 CST 2004
Steve,
Good to hear there's some improvement. Here are a couple suggestions.
32 bit:
The AGServiceManager log file is normally in
~/.AccessGrid/Logs/AGServiceManager.log
but if there's an error before initialization, you might find information
in a .aglog file in /tmp.
It looks like there's an exception calling AGTkConfig.instance(0) in
Toolkit.py. If you want to debug that call, note that the AGTkConfig
class being used is defined in Platform/unix/Config.py.
It could be that the necessary toolkit directories don't exist -- they are
usually created at install time or with CvsSetup.py:
python tools/CvsSetup.py -a .
. env-init.sh
64 bit:
I'm not sure what the real problem is, but if you use grid-proxy-init
with -cert and -key options and the certificate files you exported, you
should be able to tell if there is a problem with your globus environment.
If that works, trying an anonymous certificate from within the AG
Toolkit is another good (and quick) test.
Eric
On Wed, 17 Nov 2004, Steven Woolsey wrote:
> Eric,
> Thanks for your reply.
> pyGlobus is installed, but it looks like there is something missing.
> When I tried the last import line at a python prompt:
> from pyGlobus.io import GSITCPSocketServer, ThreadingGSITCPSocketServer
> python said it couldn't find one of the globus libraries:
> libglobus_io_gcc32dbgpthr.so.0. Looking for that file, I realized that
> I had built globus for gcc32pthr instead of gcc32dbgpthr, so the
> filename it was looking for was not there. I must have messed up with
> my last compile of globus. I recompiled globus and no longer get that
> error.
> I do have another couple of issues now, but it is different on 32 bit
> versus 64 bit.
> 32 bit: I run the AGServiceManager.py and get the following error:
> Toolkit Initialization failed, exiting.
> Initialization Error: -1
> I tried looking in the .AccessGrid directory, but am unsure what logs to
> look at. Which log should I look at to find the problem?
> 64 bit:
> The scripts are running, but it appears that something is wrong with the
> certificates. I exported my certificate from the 32 bit machine and put
> it on the 64 bit one. Importing worked fine, but now when I try to
> start a proxy it tells me my pass phrase is invalid. Trying
> 'grid-proxy-init -debug' tells me:
> ERROR: Couldn't find valid credentials to generate a proxy.
> grid_proxy_init.c:485:
> globus_gsi_system_config.c:3817:
> globus_gsi_sysconfig_get_user_cert_filename_unix:
> Error with certificate filename: The user cert could not be
> found in:
> 1) env. var. X509_USER_CERT=NULL
> 2) /home/woolsr/.globus/usercert.pem
> 3) /home/woolsr/.globus/usercred.p12
> Any ideas?
> Thanks,
> Steve
> Eric Olson wrote:
> >Hi Steven,
> >It looks like a pyGlobus installation is missing. Can you make sure
> >you've built and installed pyGlobus (and globus)? It looks like you need
> >pyGlobus in /usr/lib64/python2.3/site-packages.
> >Eric
> >>I am currently trying to get a working build of AG 2.3 to work under
> >>mandrake 10.x for both 32 bit and x86_64. I have most of the packages
> >>built, but when I try to start the AGServiceManager I get the following
> >>error:
> >>Traceback (most recent call last):
> >> File "/usr/bin/AGServiceManager.py", line 23, in ?
> >> from AccessGrid.hosting import SecureServer
> >> File
> >>"/usr/lib64/python2.3/site-packages/AccessGrid/hosting/__init__.py",
> >>line 120, in ?
> >> SetHostingImpl(__hostingImpl)
> >> File
> >>line 62, in SetHostingImpl
> >> s = __import__(nis, globals(), locals(), ["SecureServer",
> >> File
> >>"/usr/lib64/python2.3/site-packages/AccessGrid/hosting/SOAPpy/Server.py",
> >>line 20, in ?
> >> from SOAPpy.GSIServer import ThreadingGSISOAPServer, GSIConfig
> >> File "/usr/lib64/python2.3/site-packages/SOAPpy/GSIServer.py", line
> >>74, in ?
> >>ImportError: cannot import name GSITCPSocketServer
> >>Obviously I am missing something. Does anyone have any suggestions of
> >>what I might look at to resolve these problems?
> Steven Woolsey
> woolsr at inel.gov
> Senior Engineer/Scientist
> Visualization Engineer
> INEEL
