[AG-TECH] New Fedora AGTk 2.3 RPMs released
Douglas Kosovic
douglask at itee.uq.edu.au
Tue Nov 16 17:45:17 CST 2004
Hi Todd,
> However, one aspect that still doesn't work is my Logitech Quickcam Pro
> with the newest build of Vic. For some reason, it causes my Quickcam to
> not produce any capture (just grey/green output). I've had that symptom
> before when the drivers were not installed correctly; however in this case
> the drivers are working fine - and when I switch to an earlier build of
> vic, all is well again.
Thanks for the bug report.
I've reproduced the bug using a Logitech on FC3 with the new
reverse-engineered pwc driver from http://www.saillard.org/pwc/ (which
should be included in kernel 2.6.10).
> Anyway, I've just replaced your vic version with an earlier version and
> all seems to be working great again. Email if you'd like to see some
> logs, etc.
A description of the bug and code fix can be found at:
http://bugzilla.mcs.anl.gov/accessgrid/show_bug.cgi?id=1203
I might put up a new vic binary for people to test, before I release a new
RPM (and new VideoProducer and Video service zip files with the fixed vic
for people who have downloaded an existing AccessGrid RPM, but don't want to
download it again).
Doug
