[AG-TECH] BridgeServer trouble
    Michael Braitmaier
    braitmaier at hlrs.de
    Mon Nov 15 08:01:19 CST 2004
Please see below!
----- Original Message -----
From: "Christoph Willing" <willing at itee.uq.edu.au>
To: "Michael Braitmaier" <braitmaier at hlrs.de>
Cc: "West Suhanic" <wsuhanic at alumni.uwaterloo.ca>; "Thomas D. Uram"
<turam at mcs.anl.gov>; <ag-tech at mcs.anl.gov>
Sent: Monday, November 15, 2004 1:54 PM
Subject: Re: [AG-TECH] BridgeServer trouble
> On 15/11/2004, at 7:36 PM, Michael Braitmaier wrote:
>> HEllo chris!
>> I am using a quite small port range with our bridgeserver here at our
>> institute, only allowing a port range of 4 ports, which is exactly  what
>> is needed to bridge one room. For example:
>> #HLRS AG Room on ANL Server
>> [https://hume.mcs.anl.gov:9000/Venues/
>> 000000f5569d3f0a008c00dd000b003761b]
>> type=Venue
>> portMin=50096
>> portMax=50099
>> Two ports are allocated for audio (in/out) and two ports are allocated
>> for video (in/out).
>> Works quite stable.
> Michael,
> Since you had success, I just tried mine again and it worked fine.
> I did do one thing differently and this seems to be significant. My
> original port number range was portMin=24000, portMax 24004 ( they were
> just commented out in the bridge.conf file). I changed them to 24000 &
> 24003 and it worked perfectly. When I changed back to the original  24000
> & 24004, I had errors again,namely:
>     can't bind ucaddr to socket!: Address already in use
That is related to something different. The port allocator code uses a
random port allocation method. I changed the code of my AccessGrid
installation, to have a repeatable intervall allocation of ports.This means
everytime I start the bridge the ports will be allocated starting with
<PortMin> and ending with <PortMax>.
The normal AG distribution uses a random number generator to allocate the
ports so it is possible that one uc-port might be used for different
mc-ports, due to a bug (i guess) in the portallocator python script, which I
also fixed to have a stable track of ports already used.
Michael
> When I changed back to 24000 & 24003 and problem disappeared. So its
> working now, but I think something is still not quite perfect in the  port
> allocation.
> So West, thats something else you could try: I see that your port range
> was 24000-24006. What happens if you try portMin=24000 and  portMax=24003?
> chris
> Christoph Willing                        Ph: +61 7 3365 8350
> QPSF Access Grid Manager
> University of Queensland
