[AG-TECH] BridgeServer trouble
Christoph Willing
willing at itee.uq.edu.au
Sun Nov 14 16:04:53 CST 2004
On 14/11/2004, at 2:33 AM, West Suhanic wrote:
> Hi Thomas:
> I am running my own VenueServer. It is located at,
> https://example1:8000/Servers/default
> In order to allow non-multicast enabled hosts access to the
> VenueServer I am running a
> bridge server on example1. The configuration file for the BridgeServer
> is:
> [BridgeServer]
> name = CLR
> location = Toronto
> qbexec = /usr/bin/QuickBridge
> # Lobby of ag-2 server
> [https://example1:8000/Venues/default]
> type = Venue
> # use this special port range for this venue
> portMin = 24000
> portMax = 24006
> I can successfully connect to the VenueServer and select unicast.
> After selecting
> unicast, a new rat and vic appear. However I never get any video or
> audio. All of
> my multicast VenueClients are getting video and audio from the
> VenueServer.
> Any suggestions as to what I am doing wrong?
West,
Just as a test, try a configuration with a much greater range between
portMin & portMax e.g. portMin = 20000, portMax =30000.
I think there's something amiss with port number allocations when
min/max are so close. I previously tried a narrow range like yours (in
order to try to generate specific, repeatable port numbers), but it
didn't work as expected. Unfortunately I didn't have time to track down
the problem, so left it to the bridge service to select port numbers
from a wide range.
chris
Christoph Willing Ph: +61 7 3365 8350
QPSF Access Grid Manager
University of Queensland
