[AG-TECH] Node setup Wizard
Derek Piper
dcpiper at indiana.edu
Tue Nov 9 07:20:55 CST 2004
Patrick,
Do you already have alsa installed? You might try Uvh instead too. Try
installing all the RPMs except the alsa ones and see where that gets
you. Since I didn't have a problem, I'm merely guessing I'm afraid.
Derek
Patrick Johnson wrote:
> I got 2.3 to install fine on XP Pro but I'm having trouble with the
> RHEL. I download all the RPMs from the Fedora Core 1 as you suggested.
> However, when I try to install them the system hangs. I used the
> command in the following order ...
> Rpm -ivh wxGTK* alsa* openoffice* gpt* wxPython* globus* wxmozilla*
> AccessGrid*
> I get the following output and then it hangs ...
> Warning wxGTk2.4.2-0.fdr.1.1.i386.rpm: V3 DSA signature: NOKEY, key ID
> 8df56d05
> Preparing... ############################################ [100%]
> 1:alsa-lib ############################################ [8%]
> I'm running kernel 2.4.21-20.EL
> I appreciate your help,
> Patrick
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
> Behalf Of Derek Piper
> Sent: Friday, November 05, 2004 10:32 AM
> To: ag-tech at mcs.anl.gov
> Subject: Re: [AG-TECH] Node setup Wizard
> Patrick,
> I agree with David. Use 2.3, I had an amazingly easier time
> getting
> things to work, not to mention 2.3 is a usable speed (2.2 was slow as
> molasses for me for some reason).
> For simplicity and to avoid confusion I would uninstall previous
> versions as much as possible.
> For Windows, get and install the following:
> AGTk-2.3-Py-2.3.exe
> ActivePython-2.3.2-232-win32-ix86.msi
> wxPythonWIN32-2.5.1.5-Py23.exe
> For RedHat, get and install all the RPMS from here:
> http://www.itee.uq.edu.au/~grangenet/ag_fedora/FC1/stable/RPMS/
> You should probably read these notes too:
> Yes, it says Fedora Core1, but they work with no problems in
> RedHat9.
> I'd hope it'd work on Enterprise too. If they're dedicated machines you
> could always go the Gentoo route too, since it appears to be 'officially
> supported' by ANL.
> I have a RedHat and XP machine for our node and it worked great.
> I had
> the whole lot running in an hour.
> Derek
>>I am trying AGTk 2.2 I thought that 2.2 being one version behind the
>>latest would provide me with the most documentation and stability.
>>I'm on a tight deadline to get this up and running. I'm looking for
> the
>>easiest and most documented path to getting a Access Grid Node up and
>>running.
>>I have two RedHat Enterprise Linux computers and one XP Pro computer.
>>Do I need to uninstall everything and start over? What version should
> I
>>go with?
>>Patrick
>>From: David McNabb [mailto:mcnabb at umd.edu]
>>Sent: Friday, November 05, 2004 5:36 AM
>>To: Patrick Johnson
>>I hope you meant 2.3 or 2.1.
>>IMHO, 2.2 was a mess and should be avoided.
>>2.3 is much more stable and functional.
>>Go directly to 2.3 or stay at 2.1.
>> --David McNabb
>>From: "Patrick Johnson" <pjohnson at imsav.com>
>>To: <ag-tech at mcs.anl.gov>
>>Date: Thu, 4 Nov 2004 15:36:35 -0800
>>Subject: [AG-TECH] Node setup Wizard
>>I'm having trouble running the Node Setup Wizard under AGTk 2.2
>>I have two Linux systems running RHEL v.3 (audio and video capture)
> and
>>one Windows XP Pro system for my display.
>>I first started the AGServiceManager.py on each of the Linux systems.
>>Each system replies with a "bound to port 12000" and no errors.
>>The XP system also starts the Service Manager Service with no errors
> but
>>when I start the Node Setup Wizard I get an error "Can not start Node
>>Setup Wizard". There are no other error messages and nothing in the
>>event viewer. Has anyone else had this problem?
>>Thanks,
>>Patrick Johnson
>>Integrated Media Systems
>>1260 N. Fee Ana
>>Anaheim, CA 92807
>>office: 714-579-4100
>>cell: 714-225-0666
Derek Piper - dcpiper at indiana.edu - (812) 856 0111
IRI 323, School of Informatics
Indiana University, Bloomington, Indiana
