[AG-TECH] Running VenueServer 24/7
Randy Groves
randy.groves at boeing.com
Mon Nov 1 15:55:08 CST 2004
Ah! Another page from the 'Secret Papers'!!
(just kidding ... but it's so much easier than switching the cert around in
the venue client, and I can set up the client as a 'real' user now ...)
-randy
At 12:09 PM 11/1/2004, Thomas D. Uram wrote:
>What you want is to request a VenueServer service certificate that you can
>use to run your venue server. The service certificate has no passphrase,
>so it is used directly by the venue server (instead of having to generate
>a short-lived proxy certificate).
>When you request the service cert, you can use the certificate manager to
>write a service profile. You can then, after retrieving the service cert,
>run your Venue Server like so:
>VenueServer.py --profile <profileName>
>Tom
>Derek Piper wrote:
>> Hi,
>> I have been running a venue server, hoping to make sure I can keep
>> one running reliably. I have found that although it will run with no
>> problems during a day, the following day it has disconnected all
>> participants and when attempting to join again I get 'Authorization
>> failed'. Stopping and starting the VenueServer has things working again.
>> Is this due to a globus proxy expiration? If so, how do I get around
>> that problem?
>> Thanks,
>> Derek
