[AG-TECH] Running VenueServer 24/7
Thomas D. Uram
turam at mcs.anl.gov
Mon Nov 1 14:09:16 CST 2004
What you want is to request a VenueServer service certificate that you
can use to run your venue server. The service certificate has no
passphrase, so it is used directly by the venue server (instead of
having to generate a short-lived proxy certificate).
When you request the service cert, you can use the certificate manager
to write a service profile. You can then, after retrieving the service
cert, run your Venue Server like so:
VenueServer.py --profile <profileName>
Tom
Derek Piper wrote:
> Hi,
> I have been running a venue server, hoping to make sure I can keep
> one running reliably. I have found that although it will run with no
> problems during a day, the following day it has disconnected all
> participants and when attempting to join again I get 'Authorization
> failed'. Stopping and starting the VenueServer has things working again.
> Is this due to a globus proxy expiration? If so, how do I get around
> that problem?
> Thanks,
> Derek
