[AG-TECH] Multiple identical stream fix for Winnov Videum 440	0 capture card
    Osland, CD (Chris)
    C.D.Osland at rl.ac.uk
    Fri May 14 03:43:22 CDT 2004
Someone has just asked about the 'fix' to get the Videum 4400
working with VIC without inSors plugin or whatever.  Here is
Matt Thorpe's e-mail in which he documented the registry fix
he developed.
Chris
____________________________________________________________________
Chris Osland                                               Office tel: +44
(0) 1235 446565
Digital Media and Access Grid                          Medialab tel: +44 (0)
1235 446459
BIT Department                                     Access Grid room tel: +44
(0) 1235 445666
e-mail:   C.D.Osland at rl.ac.uk                                       Fax: +44
(0) 1235 445597
CLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and are for the use of the
intended recipient only.
If you are not the intended recipient do not take any action on it or show
it to anyone else,
but return this email to the sender and delete your copy of it.]
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> Behalf Of Thorpe, MS (Matt)
> Sent: 06 April 2004 14:09
> To: 'ag-tech at mcs.anl.gov'
> Subject: [AG-TECH] Multiple identical stream fix for Winnov
> Videum 4400
> capture card
> Hi all,
> I came across an 'undocumented feature' whilst trying to set
> up a single
> node AG using the Winnov Videum 4400 4 channel capture card
> in that all of
> the outgoing streams were from the same source.  I have documented the
> registry fix below that will resolve this.
> Please post to the group with your feedback!
> Matt.
> | AG2.1.2 registry fix for Winnov Videum 4400 capture card |
> | 2nd March 2004 - Matt Thorpe, m.s.thorpe at rl.ac.uk        |
> | CCLRC Rutherford Appleton Laboratories, UK               |
> This document details how to fix the fault with AG2.1.2 and the Winnov
> Videum 4400 4 channel capture card where all outgoing streams
> are sourced
> from the same channel.
> Open regedit.exe and navigate to the following path:
> 	HKEY_CURRENT_USER\Software\Winnov\Videum\
> Ensure that vic.exe[x] (where [x] is between 0-3,
> corresponding to the 4
> capture channels) has it's 'Source' key set to [x].  Do this with
> WnvConfig.exe[x] in the same way.  For example the Source key in
> HKEY_CURRENT_USER\Software\Winnov\Videum\vic.exe1 should be 1.
> Reboot the computer to make these changes take effect.
> If this does not work delete any key directories within this
> path that don't
> start with either vic.exe or WnvConfig.exe.
> This problem seems to be caused by the Winnov Configure
> application, so I
> would recommend not using this unless you really need to, and
> be prepared to
> reapply these registry patches if you do!
> On our two test systems this fixed the fault and it also
> retains the camera
> / channel mappings through reboots and venue changes etc.
