[AG-TECH] Image quality
    Osland, CD (Chris)
    C.D.Osland at rl.ac.uk
    Thu May 13 04:22:44 CDT 2004
Nothing about your equipment, of itself, should cause any major
image quality deterioration.  Of course, if the camera has been
used before and left pointed at a bright source for a long time,
say in a surveillance role, it could be the problem.  Equally if
someone has set up the monitors for a particular application, they
could be the problem.  If you have a decent AV department around,
you could try to eliminate the camera as the problem by plugging
in a video signal generator instead, with it set to colour bars,
and see how they come out - they should really shine on a PC
monitor.  If they do, then try a different camera.  If they don't,
look at the display side of things.  Make sure you don't have any
excessive cable runs - many cameras don't have very powerful output
drivers and the first thing to go can be colour.  Also check you
are using proper video cable from camera to capture card - an
underspecified cable will lose high frequencies (say above 3 MHz)
more than lower ones, and so reduce the colour information.
Cheers
Chris
____________________________________________________________________
Chris Osland                                               Office tel: +44
(0) 1235 446565
Digital Media and Access Grid                          Medialab tel: +44 (0)
1235 446459
BIT Department                                     Access Grid room tel: +44
(0) 1235 445666
e-mail:   C.D.Osland at rl.ac.uk                                       Fax: +44
(0) 1235 445597
CLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and are for the use of the
intended recipient only.
If you are not the intended recipient do not take any action on it or show
it to anyone else,
but return this email to the sender and delete your copy of it.]
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> Behalf Of Natalia Costas Lago
> Sent: 13 May 2004 08:43
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] Image quality
> Hi all,
> We have noticed that image color in our videostream seems to
> have a lack of
> ....accuracy to reality... i've seen other video streams that seem to
> reflect colors better and probably in a more real way. I was
> wondering where
> in the chain we can fix that. We are using a provisional Sony EVI D30
> camera, pinnacle pctv pro capture cards (i've tried as well
> with osprey 500,
> osprey 100 and hauppauge wintv go). Our display grahpics card
> is a nvidia
> quadro nvs and, finally, our display right now is composed of
> a brand new
> fujitsu TFT and a plasma TV.
> The codecs we are using are h261 (i think h263 cant be used
> with AG2.1.2 so
> far, is there any date about when will it be available?).
> Can anyone give us a piece of advice where we can improve our
> video quality?
> Kind regards and thank you in advance.
> Natalia.
> Natalia Costas Lago
> email: natalia at cesga.es
> Centro de Supercomputacion de Galicia (CESGA)
> Avenida de Vigo, s/n Campus Sur
> 15705 Santiago de Compostela - SPAIN
> Tel:   +34  981 56 98 10
> Fax:  +34  981 59 46 16
> http://www.cesga.es/
