[AG-TECH] Cameras
    Osland, CD (Chris)
    C.D.Osland at rl.ac.uk
    Thu May 13 04:00:30 CDT 2004
I didn't think the D30 (NTSC / D-31 (PAL) ) was still made.  It
has been replaced by the D-100.  Neither D30/31 nor D-100 can be
successfully mounted camera-down on a ceiling, as they don't have
an image reverse feature.  For that we use the Elmo PTC-250C, which
is reputed to obey the same serial protocol as the Sonys.
We have a mix - 8 Sony D-31, 5 Sony D-100 and 1 Elmo PTC-250C
spread over four nodes.  I wish the Sony's had something less
on/off that Backlight Compensation - like a decent settable iris -
but we've just about got the lighting right so this is less of a
problem.
Cheers
Chris Osland
____________________________________________________________________
Chris Osland                                               Office tel: +44
(0) 1235 446565
Digital Media and Access Grid                          Medialab tel: +44 (0)
1235 446459
BIT Department                                     Access Grid room tel: +44
(0) 1235 445666
e-mail:   C.D.Osland at rl.ac.uk                                       Fax: +44
(0) 1235 445597
CLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and are for the use of the
intended recipient only.
If you are not the intended recipient do not take any action on it or show
it to anyone else,
but return this email to the sender and delete your copy of it.]
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> Behalf Of Jon Johansson
> Sent: 13 May 2004 01:17
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] Cameras
> I'm building a couple of new nodes and would like to know
> if people have found alternatives to the old standard
> cameras, Sony EVI-D30 and Canon VC-C3, mentioned in the
> the equipment recommendation list. That list is getting
> a bit old and the Canon has been replaced by a new model.
> What other cameras are people finding usable for
> nonpersonal nodes? We've been using the Sonys and they are
> very nice, but perhaps there is something cheaper that
> works as well?
> Thank you,
> Jon.
> Jon I Johansson             *  Research Computing Support
> jon.johansson at ualberta.ca   *  Computing and Network Services
> Tel.: (780) 492-9304        *  University of Alberta
> Fax.: (780) 492-1729        *  Edmonton, Alberta, CANADA
