[AG-TECH] Re: AG 2.2 Alpha - node services do not start when 	entering a venue
    Ivan R. Judson
    judson at mcs.anl.gov
    Mon May 10 15:24:11 CDT 2004
You should just keep an eye out for new snapshots. Otherwise you might not
get prodded until the beta. We're not posting new snapshot announcements
with any reliability. Also you'll want to not leave the binaries in the bin
directory or you'll get a very confused installation.
--Ivan
  _____
From: Andrew Patrick [mailto:Andrew.Patrick at nrc-cnrc.gc.ca]
Sent: Monday, May 10, 2004 3:19 PM
To: judson at mcs.anl.gov
Cc: ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] Re: AG 2.2 Alpha - node services do not start when
entering a venue
Thanks for the reply.  Putting the RAT and VIC executables in the bin
directory did allow these services to start, so something is still looking
for them in the old places.
I did not get much further with 2.2Alpha, having problems connecting to
most, but not all, venue servers.
Let us know when we should test it again.
Ivan R. Judson wrote:
The original alpha snapshot is known to not start the services and shared
apps don't work either. We're working on these problems and plan to announce
when things change functionally (stay tuned).
As for your question about vic and rat not being in bin, the reason you
didn't find them is because that's not where they go now. They are unpacked
and installed as part of the audio or video node services. This is a change
from previous versions of the toolkit. The underlying tools are kept in node
service specific locations which allow us to use multiple different
configurations -- we could now support having and openmash vic video service
(which would enable H.263).
Don't look for random media tools to reappear in the bin directory, we're
not planning on that happening.
--Ivan
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov
> [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Andrew Patrick
> Sent: Monday, May 10, 2004 11:15 AM
> Subject: [AG-TECH] Re: AG 2.2 Alpha - node services do not
> Further investigation suggests that VIC and RAT have not been
> installed in the bin directory.  I copied vic.exe from the
> ZIP file for the video service, but RAT does not seem to be
> in the corresponding audio service.
> So, is it possible that all the components are not getting
> installed in a fresh install of 2.2 Alpha?
> Andrew Patrick wrote:
> > OK I thought I would try the AG 2.2 Alpha software at home (Windows
> > XP). Everything seemed to install OK, and I was able to import my
> > certificates.  The problem is that when I navigate to a
> Venue neither
> > RAT nor VIC start up.  The Node services are defined and
> enabled, as
> > far as I can tell.
> > Any idea where to look for problems.
> > BTW, this I installed the daily snapshop today.
> > Andrew Patrick
> > NRC Canada
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040510/b69cc6c2/attachment.htm>
