[AG-TECH] Re: AG 2.2 Alpha - node services do not start when entering a venue
Ivan R. Judson
judson at mcs.anl.gov
Mon May 10 13:18:32 CDT 2004
The original alpha snapshot is known to not start the services and shared
apps don't work either. We're working on these problems and plan to announce
when things change functionally (stay tuned).
As for your question about vic and rat not being in bin, the reason you
didn't find them is because that's not where they go now. They are unpacked
and installed as part of the audio or video node services. This is a change
from previous versions of the toolkit. The underlying tools are kept in node
service specific locations which allow us to use multiple different
configurations -- we could now support having and openmash vic video service
(which would enable H.263).
Don't look for random media tools to reappear in the bin directory, we're
not planning on that happening.
--Ivan
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov
> [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Andrew Patrick
> Sent: Monday, May 10, 2004 11:15 AM
> Cc: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] Re: AG 2.2 Alpha - node services do not
> Further investigation suggests that VIC and RAT have not been
> installed in the bin directory. I copied vic.exe from the
> ZIP file for the video service, but RAT does not seem to be
> in the corresponding audio service.
> So, is it possible that all the components are not getting
> installed in a fresh install of 2.2 Alpha?
> Andrew Patrick wrote:
> > OK I thought I would try the AG 2.2 Alpha software at home (Windows
> > XP). Everything seemed to install OK, and I was able to import my
> > certificates. The problem is that when I navigate to a
> Venue neither
> > RAT nor VIC start up. The Node services are defined and
> enabled, as
> > far as I can tell.
> > Any idea where to look for problems.
> > BTW, this I installed the daily snapshop today.
> > Andrew Patrick
> > NRC Canada
