[AG-TECH] Re: AG 2.2 Alpha - node services do not start when entering a venue
    Andrew Patrick
    Andrew.Patrick at nrc-cnrc.gc.ca
    Mon May 10 11:14:35 CDT 2004
Further investigation suggests that VIC and RAT have not been installed
in the bin directory.  I copied vic.exe from the ZIP file for the video
service, but RAT does not seem to be in the corresponding audio service.
So, is it possible that all the components are not getting installed in
a fresh install of 2.2 Alpha?
Andrew Patrick wrote:
> OK I thought I would try the AG 2.2 Alpha software at home (Windows
> XP). Everything seemed to install OK, and I was able to import my
> certificates.  The problem is that when I navigate to a Venue neither
> RAT nor VIC start up.  The Node services are defined and enabled, as
> far as I can tell.
> Any idea where to look for problems.
> BTW, this I installed the daily snapshop today.
> Andrew Patrick
> NRC Canada
