[AG-TECH] Still nothing
    Aaron Lafferty
    lafferty at oar.net
    Mon May  3 16:03:32 CDT 2004
Michael,
Yes, that is what I am doing.  If I run VenueClient and select
preferences, manage my node:
NodeManager starts in connected state, I can add localhost (display
machine), and services to that host.  I however cannot add the video or
audio capture devices.  Attempts to do so result in:
Exception: Service Manager is unreachable:
https:://x:12000/ServiceManager
Which as I mentioned, is not the case when a browser from the display
machine is pointed at that URL.
Thanks!
Aaron
On Mon, 2004-05-03 at 16:36, Michael Miller wrote:
> Aaron,
> Let me make sure I understand,  you're running the NodeManager.py at a
> prompt rather than going to the VenueClient and selecting
> Preferences->ManageMyNode
> If this is the case, what happens when you run Preferences->ManageMyNode
> from the VenueClient?
> Michael Miller
> NCSA
> At 03:18 PM 5/3/2004, Aaron Lafferty wrote:
> >Hey all...
> >So I've been reading some documentation I found here
> >http://www-unix.mcs.anl.gov/fl/research/accessgrid/documentation/RoomBasedNode-HowTo/RoomBasedNode-HowTo.html
> >So here's my setup:
> >#### On the windows xp pro box
> >no internet connection firewall!
> >I start the AGNodeService.py script... it tells me its started on port
> >11000 I can verify this via telnet
> >I start the AGServiceManager script... it tells me that its started on
> >port 12k I can verify this via telnet as well
> >#### On the audio capture box fedora core 1
> >iptables is off!
> >I start the AGServiceManagerscript... it tells me that its started on
> >port 12k
> >i can set a browser to https://x:12000/ServiceManager and it challenges
> >me for an identification certificate
> >#### on the video capture device fedora core 1
> >iptables is off!
> >port 12k
> >Ok to here this seems like everything is the way it should be right?
> >Originally I had 3 different certs on these boxes (probably shouldn't
> >have)... i have imported on cert to all boxes and that is the only one
> >they use... I destoryed the globus proxy so it made me create another
> >with the new cert.
> >Time's are synced to within a fraction of a second of one another...
> >If I run the AGVenueClient from the display (xp) box it runs and
> >connects fine to the default venue server.  So outbound to that works...
> >If I run the NodeManager script as it says to do in the documentation I
> >cited above (this is not from the AGVenueClient, but the standalone node
> >manager)  It comes up but is not connected.  If I use file and localhost
> >nothing happens (port 11k) I use the FQDN, nothing... the IP address
> >nothing!
> >If I try adding services through the service manager menu option I
> >receive Error Adding Service Manager for both the audio and video
> >capture device.  This occurs on both the FQDN, IP address, and hostname.
> >Anybody have any clues for me?
> >Thanks!
> >Aaron
> Thanx,
> Michael Miller
> System Engineer
> Visualization Technology Support
> Computing and Data Management
> National Center for Supercomputing Applications
> University of Illinois - UC
> 217-649-0747
> "If you're clear in your vision and trust the people in your team with
> clear objectives, they will invariably do their best to achieve everything
> desired, and usually deliver everything you could have hoped for and even
> more." -Paul Debevec
