[AG-TECH] Still nothing
    Aaron Lafferty
    lafferty at oar.net
    Mon May  3 15:18:55 CDT 2004
Hey all...
So I've been reading some documentation I found here
http://www-unix.mcs.anl.gov/fl/research/accessgrid/documentation/RoomBasedNode-HowTo/RoomBasedNode-HowTo.html
So here's my setup:
#### On the windows xp pro box
no internet connection firewall!
I start the AGNodeService.py script... it tells me its started on port
11000 I can verify this via telnet
I start the AGServiceManager script... it tells me that its started on
port 12k I can verify this via telnet as well
#### On the audio capture box fedora core 1
iptables is off!
I start the AGServiceManagerscript... it tells me that its started on
port 12k
i can set a browser to https://x:12000/ServiceManager and it challenges
me for an identification certificate
#### on the video capture device fedora core 1
iptables is off!
port 12k
Ok to here this seems like everything is the way it should be right?
Originally I had 3 different certs on these boxes (probably shouldn't
have)... i have imported on cert to all boxes and that is the only one
they use... I destoryed the globus proxy so it made me create another
with the new cert.
Time's are synced to within a fraction of a second of one another...
If I run the AGVenueClient from the display (xp) box it runs and
connects fine to the default venue server.  So outbound to that works...
If I run the NodeManager script as it says to do in the documentation I
cited above (this is not from the AGVenueClient, but the standalone node
manager)  It comes up but is not connected.  If I use file and localhost
nothing happens (port 11k) I use the FQDN, nothing... the IP address
nothing!
If I try adding services through the service manager menu option I
receive Error Adding Service Manager for both the audio and video
capture device.  This occurs on both the FQDN, IP address, and hostname.
Anybody have any clues for me?
Thanks!
Aaron
