[AG-TECH] Need help installing web cam
Chan Hoong Maeng
chanhm at ihpc.a-star.edu.sg
Thu Mar 25 21:41:07 CST 2004
I think you need to configure your vic to use the correct web cam.
To do that, you need to click on the Menu button after vic is launched.
Next, click on Options -- Configure on Transmit, followed by Release and
then Transmit. This procedure will launch a dialog window that allows
you to select and configure your web cam to use with vic.
Hoong_Maeng Chan
Institute of High Performance Computing
Singapore
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
Behalf Of stout at csee.wvu.edu
Sent: Friday, March 26, 2004 1:04 AM
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] Need help installing web cam
Hello, I have been trying to add a Logitech Quickcam Express to a PIG. I
setup the Video Producer service and select the QuickCam Express driver.
However, when I enter a venue, I get the following error
message:Microsoft Visual C++ Runtime Library
Runtime Error!
Program: C:\Program Files\Access Grid Toolkit\bin\vic
This application has requested the Runtime to terminate in an unusual
way.
Please contact the application's support team for more information.
Could anyone offer any help in resolving this error? I've tried a couple
of other webcams, but have come up with the same result. Thank you.
