[AG-TECH] Re: Invalid Passphrase - getting closer!
Darin Oman
darin at ucar.edu
Fri Mar 19 09:45:23 CST 2004
Thanks for the help, all. I did restart the client as well as the computers with no luck. It's all working again this morning. The video machine seems to have been a bit confused (technical terms) between certs. I wasn't getting the error message that the passphrase expired on the video machine, so there was still a valid proxy to the expired certificate, or something like that. Anyway, it's all good now.
For future reference: is there a way to kill the proxy before the allotted time is up?
Darin
On 3/18/2004 at 2:56 PM Michael Miller wrote:
>Darin,
>I've seen this a few times myself. Once you imported your cert, did you
>close your client and restart it? or did you try to go directly to "Manage
>My Node"? I seem to recall that restarting the client solved the
>problem. I haven't investigated it completely tho'.
>Michael Miller
>NCSA
>At 12:37 PM 3/18/2004, you wrote:
>>OK, I got my new cert, installed it on both machines of my room node, and
>>I ran into a new problem. I can now get into the Display/audio machine
>and
>>all looks good there. I can also start the service manager on the video
>>machine. I've checked the certs on both machines and they're identical
>and
>>set to default. It all looks good until I try to connect the display
>>machine to the video machine. I get "can't locate service manager..." The
>>time on both machine is in sync, so I don't think that's the problem. Any
>>ideas?
>>Darin
>>On 3/18/2004 at 10:06 AM Robert Olson wrote:
>>If you're running 2.x you can request one thru the cert request tool.
>>Someone will be around all day that can sign it for you.
>>--bob
>>At 09:58 AM 3/18/2004, Darin Oman wrote:
>>>Yep, it looks like the cert is expired. Is there a way to quickly get a
>>>new one, or should I change the date on the machine to make it through
>>>the day? I could also go back to AG 1.x, but I'd hate to have to move
>>>backward.
>>>Darin
>>>On 3/18/2004 at 9:31 AM Robert Olson wrote:
>>>Try bringing up the cert mgr and have a look at your default cert; I'm
>>>wondering if it has expired. (latest code has a lot more detail on cert
>>>failures, btw, so this sort of thing will be more obvious).
>>>--bob
>>>At 09:13 AM 3/18/2004, Darin Oman wrote:
>>>>Hello,
>>>>I'm suddenly unable to log into a venue client on my AG2 systems. I've
>>>>tried 2 (they use the same passphrase and I think the same certificate)
>>>>and I'm getting an "invalid passphrase" message on both. Can anyone
>help?
>>>>Thanks,
>>>>Darin
>>Thanx,
>>Michael Miller
>>System Engineer
>>Visualization Technology Support
>>Computing and Data Management
>>National Center for Supercomputing Applications
>>University of Illinois - UC
>>217-649-0747
>>"If you're clear in your vision and trust the people in your team with
>>clear objectives, they will invariably do their best to achieve
>everything
>>desired, and usually deliver everything you could have hoped for and even
>>more." -Paul Debevec
