[AG-TECH] AG1 dppt
Fred Dech
fdech at uchicago.edu
Wed Mar 10 09:35:45 CST 2004
there is a link directly to msjavx86.exe on
http://hp.vector.co.jp/authors/VA012735/vm_en.html
i kept using jvm
in my search parameters. the trick, as Mike Miller pointed out to me, is
to search for msjavx86.exe.
thanks.
--fred
On Wed, Mar 10, 2004 at 10:28AM, Mike Weaver said:
> You might want to try this link:
> http://java-virtual-machine.net/download.html
> It's a multi-step process, but it's all spelled out w/ appropriate
> links.
> Mike
> From: "Fred Dech" <fdech at uchicago.edu>
> To: <ag-tech at mcs.anl.gov>
> Sent: Wednesday, March 10, 2004 09:48
> Subject: [AG-TECH] AG1 dppt
> > i've set up a laptop with WinXP to be used in our room node as the
> dppt
> > master as we transition to AG2.
> > unfortunately, jview and the MS JVM seems to be impossible to find.
> the
> > service packs on the machine were completely updated before i
> installed
> > dppt3 and came across this realization.
> > i've looked far and wide on sun and ms and have not been able to find
> > the MS JVM. i grabbed jview.exe from another machine, but it is
> aparently
> > only a part of the JVM. it would not execute.
> > i'm not that experienced with MSWindows. 'any trick i might employ?
> > or does anyone know where it might still exist or if it is possible to
> run
> > dppt with something other than jview?
> > thanks much.
> > --fred
Fred Dech fdech at uchicago.edu
University of Chicago Dept. of Surgery
Ph: (773) 834-8359, Fax: (773) 834-8140
