[AG-TECH] AG1 dppt
Mike Weaver
weaver at er.doe.gov
Wed Mar 10 09:28:24 CST 2004
You might want to try this link:
http://java-virtual-machine.net/download.html
It's a multi-step process, but it's all spelled out w/ appropriate
links.
Mike
----- Original Message -----
To: <ag-tech at mcs.anl.gov>
Sent: Wednesday, March 10, 2004 09:48
Subject: [AG-TECH] AG1 dppt
> i've set up a laptop with WinXP to be used in our room node as the
dppt
> master as we transition to AG2.
> unfortunately, jview and the MS JVM seems to be impossible to find.
the
> service packs on the machine were completely updated before i
installed
> dppt3 and came across this realization.
> i've looked far and wide on sun and ms and have not been able to find
> the MS JVM. i grabbed jview.exe from another machine, but it is
aparently
> only a part of the JVM. it would not execute.
> i'm not that experienced with MSWindows. 'any trick i might employ?
> or does anyone know where it might still exist or if it is possible to
run
> dppt with something other than jview?
> thanks much.
> --fred
