[AG-TECH] VenueVNCServer issues
    Eric Olson
    eolson at mcs.anl.gov
    Thu Jun 24 18:28:28 CDT 2004
Hi Michael,
Thank for trying it out.  Here are answers to some of your questions,
although the standard disclaimer applies: we're not really supporting
VenueVNCServer yet :)
1.  They can run on different machines -- the url for the venue can be on
a different machine.
2. Yes, for example, I generally use :1 since :0 is usually taken.
3. They don't need to be installed anywhere specific.  As long as you have
AG 2.2 installed and you have the files from the VenueVNC/server
directory (the current version is in cvs since it hasn't been released
yet).
4. You can fix this by running with python2 before the filename like this:
> python2 /usr/bin/VenueVNCServer.py ...
This can happen if the first line of the file doesn't say where the
python2 executable is located.  I fixed this in VenueVNCServer.py in cvs
just now, so if you use that version, you shouldn't get this error
anymore.
Let us know how it goes,
Eric
On Thu, 24 Jun 2004, Michael Braitmaier wrote:
> Hello everyone!
> I am currently trying to setup a the VenueVNCServer on one of our Linux
> computers. During this task some questions arised for me.
> 1. Is it necessary to have a Venue Server running on the same machine
> (regarding the url of the venue to be passed to the starting call of the
> VenueVNCServer) or can it be located on another machine?
> 2. I assume the display number to be the same as you would use it in
> normal Linux, starting with :0 as the standard display visible. Is that
> correct?
> 3. I didn't install the VenueServer by using the rpm, instead by just
> copying the *.py-file into the usr/bin folder together with Xvnc and
> vncrandpwd, is this sufficient or do I miss something essential to run
> the VNCserver?
> 4. When I run the VncServer I get no message output at all just the
> cursor icon changing to a cross. When clicking somewhere on the screen i
> get different messages dependent where I click on, but all finally
> resulting in the following message:
> : command not foundrver.py: line 6:
> /usr/bin/VenueVNCServer.py: line 24: syntax error near unexpected token `('
> 'usr/bin/VenueVNCServer.py: line 24: `class VNCServerException(Exception):
> It would be great if someone could give me some hints on what I am doing
> wrong as I am not that deep into Linux.
> Thanks in advance.
> Michael
> Michael Braitmaier
> HLRS
> University of Stuttgart
> Germany
> Website: http://www.hlrs.de/organization/vis/people/braitmaier/
