[AG-TECH] Osprey-100 and WinXP Access Grid Toolkit 2.2
    Fred Dech
    fdech at uchicago.edu
    Wed Jun 23 10:13:31 CDT 2004
i see what you mean.  now that i've used this system a bit more, i recognise
that i'm a similare situation.
with the Osprey XP setup.  the settings don't stick.  i have two Osprey 100s
and each time i change venues, both of my videoProducers default back to the
same Osprey card.  i also then need to re-submit my VIC rtpEmail info,
not once, not twice, but three times.  ouch.  this is not usable at this point.
--fred
On Wed, Jun 23, 2004 at 09:37AM, Chris Rosenthal said:
> Yes.  I know that that's available.  That's a real pain to have to do each
> time you change venues, though.  Also, I kept getting errors when doing it
> that way.  So, I just dropped back to 2.1.2 and everything seems good in
> that respect.
> Maybe 2.2.1 will take care of this.
> Chris
> Chris Rosenthal                               cmr at evl.uic.edu
> Electronic Visualization Lab                  (312) 996-3002
> University of Illinois at Chicago
> On Tue, 22 Jun 2004, Fred Dech wrote:
> > i just stumbled through this.
> > WinXP.  add your VideoProducerService for each capture card, then you'll have
> > some blank 1 Real Vic and 1 or more blank Vics.  for each blank Vic, select
> > 'Menu' at the bottom, and the 'Devices' drop-down should display all of your
> > Ospreys.  select a different one for each Vic.
> > hope that helps.
> > --fred
> > On Tue, Jun 22, 2004 at 09:03AM, Duncan Waddell said:
> > > Hi learned folks,
> > > Add my name to the list too.  I also have an urgent need to get an
> > > Osprey-100 card working with AGT 2.2 (WinXP).
> > > Duncan
> > > A Quay wrote:
> > > >I have the exact same problem. In a week I have to visit a college in
> > > >Miami to install an AG node and really need help on getting four Osprey
> > > >100???s working on a WinXP box.
> > > >Andy Quay
> > > >Associate Director
> > > >Digital Worlds Institute, University of Florida
> > > >-----Original Message-----
> > > >*From:* Chris Rosenthal [mailto:cmr at evl.uic.edu]
> > > >*Sent:* Friday, June 18, 2004 3:11 PM
> > > >*To:* ag-tech at mcs.anl.gov
> > > >*Subject:* [AG-TECH] Video Producer Config Help
> > > >Hello,
> > > >I know there???s been a lot of talk about configuring video capture
> > > >devices in Linux.  I???ve got four Osprey 100???s on a WinXP node and the
> > > >Video Producer Services always default to the same capture card on AGT
> > > >2.2.  There doesn???t seem to be the same options for configuring the
> > > >sources from the node management dialog (as previous versions).  Am I
> > > >supposed to enter something in the port text box?  Is there a patch out
> > > >or coming out soon that makes this easier?
> > > >I will really appreciate your help in taking care of this problem.
> > > Duncan Waddell  (BSc)
> > > Principal Scientific Officer
> > > Centre for Microscopy and Microanalysis
> > > The University of Queensland.   St. Lucia.  Qld.  4072
> > > Telephone:      +61-7-3365-4216
> > > Facsimile:      +61-7-3365-1775
> > > WWW:            http://www.uq.edu.au/nanoworld/nanohome.html
> > >        Any opinion expressed is that of the writer,
> > >    and not necessarily that of CMM or of the University.
> >   Fred Dech   fdech at uchicago.edu
> >   University of Chicago Dept. of Surgery
> >   Ph: (773) 834-8359, Fax: (773) 834-8140
