[AG-TECH] AG2.2 networking configuration
    Brian Corrie
    bcorrie at sfu.ca
    Sun Jun 20 13:59:02 CDT 2004
Hi Bob,
Is this a potential 2.1.2 to 2.2 migration issue? Did 2.1.2 set the
environment variable or was that something I did to get things to work
at one point??? 8-) I think 2.1.2 does set it explicitly doesn't it???
If 2.1.2 sets the environment variable, then when migrating to 2.2 you
will have to be careful to "unset it" if 2.2 doesn't use it. If 2.1.2
sets the environment variable and doesn't remove it on uninstall you
could have a problem like I did. Note that you won't notice the problem
until a computer changes its IP number (so most installs will probably
not notice it...).
Cheers,
Brian
Robert Olson wrote:
> If it is set, it overrides any local determination of hostname. The
> toolkit never sets it (in the registry; it will set it in the process if
> necessary and have it inherited by the process's children). I've given
> trying to set it for future use, as a check at startup time is sufficient.
> --bob
> On Fri, 18 Jun 2004, Randy Groves wrote:
>>Is GLOBUS_HOSTNAME even used anymore?  I removed it before installing 2.2,
>>and I don't see 2.2 setting it - is something wrong with my install?
>>-randy
>>On Fri, 18 Jun 2004, Brian Corrie wrote:
>>>Hi Ivan,
>>>Speaking of replacements for programs in AG 2.2 I noticed a problem
>>>recently. In 2.1.2 when my PIG node changed locations (home to office
>>>etc) there was an app that started up that changed the GLOBUS_HOSTNAME
>>>variable. I am not sure what it was called but it detected a change in
>>>the networking config and asked if I wanted to change the variable... On
>>>2.2 this does not seem to happen - is that correct? I had to go into the
>>>environment variables and change it explicitly to get it to work from
>>>home...
>>>Do you still have that app or some sort of replacement for it?
>>>Cheers,
>>>Brian
>>>Ivan R. Judson wrote:
>>>>That makes sense, clearly the discovery of devices in that code is platform
>>>>specific.
>>>>If you can write a python function that enumerates them we can integrate
>>>>that as a patch.
>>>>--Ivan
>>>>>-----Original Message-----
>>>>>From: dgolden at cp.dias.ie [mailto:dgolden at cp.dias.ie]
>>>>>Sent: Friday, June 18, 2004 9:43 AM
>>>>>To: judson at mcs.anl.gov
>>>>>Cc: ag-tech at mcs.anl.gov
>>>>>Subject: RE: [AG-TECH] AG2.2 replacement for setupvideo.py
>>>>>>We'll have to sort out what's going on.
>>>>>Haven't filed a formal bug report yet, but I immediately saw
>>>>>the problem once pointed to that method:
>>>>>/proc/video/dev doesn't exist at all on my system...
>>>>>(stock debian 2.6 kernel).
>>>>>In kernel 2.6 , the information is available via sysfs in
>>>>>/sys/class/video4linux not /proc/video/dev ...
>>>>>In 2.6 there has been a move to rationalise the /proc fs to
>>>>>be for processes only, and the sundry kernel stuff to /sys
>>>>>Neater that way, I guess.
>>>>>Best Regards,
>>>>>David Golden
