[AG-TECH] shared browser
    Susanne Lefvert
    lefvert at mcs.anl.gov
    Fri Jun 18 15:15:14 CDT 2004
George,
It would be interesting to see your Venue Client log file.  Would you mind
sending it to me?
C:\Documents and Settings\lefvert\Application
Data\AccessGrid\Logs\VenueClient.log
Susanne
On Fri, 18 Jun 2004, George Estes wrote:
>   So I just installed AG2.2 on another new machine and the shared apps work just fine.  What could be unique about my laptop that would prevent shared apps from working?
> George
> At 01:01 PM 6/18/2004 -0500, you wrote:
> >Actually, you don't have to reinstall the software, just rename the
> >file/dir and it should work.
> >Sorry for the inconvenience,
> >Susanne
> >On Fri, 18 Jun 2004, Susanne Lefvert wrote:
> >> Ok, I have been able to reproduce this error. Apparently, when installing
> >> 2.2, the old SharedApplications directory and ApplicationDatabase file
> >> remains from 2.1.2 and causes problems.  If solved this by renaming
> >> C:\Documents and Settings\<username>\Application
> >> Data\AccessGrid\Config\ApplicationDatabase
> >> as well as
> >> >C:\Documents and
> >> Settings\<username>\Application>Data\AccessGrid\Config\SharedApplications
> >> and then reinstalling the AGTk 2.2.
> >> Please let me know if this solves your problems.
> >> Susanne
> >> On Fri, 18 Jun 2004, Benedikt Bjarni Bogason wrote:
> >> > can it be because the server is running 2.1.2?
> >> > >    I tried this and I still cannot open any shared apps in 2.2?
> >> > > George
> >> > > At 09:15 AM 6/18/2004 -0500, Susanne Lefvert wrote:
> >> > >>The 2.2 shared browser should work. Have you been able to open any shared
> >> > >>application with 2.2 or is it just the shared browser that is giving you
> >> > >>trouble?  If you have problems with all your shared applications you
> >> > >> might
> >> > >>have a corrupt application database. You can solve that by renaming
> >> > >> Data\AccessGrid\Config\Application Database
> >> > >>and install the AGTK2.2 again. (Bug 962 in bugzilla).
> >> > >>Regards,
> >> > >>Susanne
> >> > >>> Hello
> >> > >>> I was trying to use the shared browser for the first time, between my
> >> > >>> node
> >> > >>> and a node in China. I was using AG 2.1.2 and multicasting, but the
> >> > >>> node
> >> > >>> in China was using AG 2.2 and was unicasting (or perhaps multicasting,
> >> > >>> I
> >> > >>> am not quite sure).
> >> > >>> I could add a browser and open it and start browsing, but the node in
> >> > >>> China was unable to open the browser. When they right-clicked on it and
> >> > >>> selected open, nothing happened.
> >> > >>> I also have version 2.2 on my node, so I switched to that, but then I
> >> > >>> ran
> >> > >>> into same difficulties as the node in china, nothing happened when i
> >> > >>> tried
> >> > >>> So we both switched to 2.1.2, and he switched computers and we both
> >> > >>> tried
> >> > >>> multicasting, that had the effect I could not hear nor see him (and
> >> > >>> vice
> >> > >>> versa) but the shared browser worked like a dream.
> >> > >>> Is this a known software issue with the 2.2 version, or is this perhaps
> >> > >>> a
> >> > >>> multicast problem? Anyone seen this problem before?
> >> > >>> Best regards,
> >> > >>> Benedikt Bogason
> >> > >>> benedikt.bogasson at bt.com
