[AG-TECH] shared browser
    George Estes
    gestes at ncsa.uiuc.edu
    Fri Jun 18 13:02:41 CDT 2004
  In my case, this is a new machine that never had 2.1.2 installed.   I tried renaming ApplicationDatabase and reinstalling 2.2 and then I tried removing the Application Database file and reinstalling 2.2, neither worked for me?
George
At 12:47 PM 6/18/2004 -0500, you wrote:
>Ok, I have been able to reproduce this error. Apparently, when installing
>2.2, the old SharedApplications directory and ApplicationDatabase file
>remains from 2.1.2 and causes problems.  If solved this by renaming
>C:\Documents and Settings\<username>\Application
>Data\AccessGrid\Config\ApplicationDatabase
>as well as
>>C:\Documents and
>Settings\<username>\Application>Data\AccessGrid\Config\SharedApplications
>and then reinstalling the AGTk 2.2.
>Please let me know if this solves your problems.
>Susanne
>On Fri, 18 Jun 2004, Benedikt Bjarni Bogason wrote:
>> can it be because the server is running 2.1.2?
>> >    I tried this and I still cannot open any shared apps in 2.2?
>> > George
>> > At 09:15 AM 6/18/2004 -0500, Susanne Lefvert wrote:
>> >>The 2.2 shared browser should work. Have you been able to open any shared
>> >>application with 2.2 or is it just the shared browser that is giving you
>> >>trouble?  If you have problems with all your shared applications you
>> >> might
>> >>have a corrupt application database. You can solve that by renaming
>> >> Data\AccessGrid\Config\Application Database
>> >>and install the AGTK2.2 again. (Bug 962 in bugzilla).
>> >>Regards,
>> >>Susanne
>> >>> Hello
>> >>> I was trying to use the shared browser for the first time, between my
>> >>> node
>> >>> and a node in China. I was using AG 2.1.2 and multicasting, but the
>> >>> node
>> >>> in China was using AG 2.2 and was unicasting (or perhaps multicasting,
>> >>> I
>> >>> am not quite sure).
>> >>> I could add a browser and open it and start browsing, but the node in
>> >>> China was unable to open the browser. When they right-clicked on it and
>> >>> selected open, nothing happened.
>> >>> I also have version 2.2 on my node, so I switched to that, but then I
>> >>> ran
>> >>> into same difficulties as the node in china, nothing happened when i
>> >>> tried
>> >>> So we both switched to 2.1.2, and he switched computers and we both
>> >>> tried
>> >>> multicasting, that had the effect I could not hear nor see him (and
>> >>> vice
>> >>> versa) but the shared browser worked like a dream.
>> >>> Is this a known software issue with the 2.2 version, or is this perhaps
>> >>> a
>> >>> multicast problem? Anyone seen this problem before?
>> >>> Best regards,
>> >>> Benedikt Bogason
>> >>> benedikt.bogasson at bt.com
