[AG-TECH] Problems while installing AGkt2.2 from source on a Debian
    Charles Moad
    cmoad at indiana.edu
    Fri Jun 18 08:02:01 CDT 2004
	I have been working on a source build for Gentoo Linux recently, and
you can always add libs to your search path like this:
export LD_LIBRARY_PATH=/usr/lib/gpt/lib
-Charlie
Joseph wrote:
> Hi all
> I have worked on the packages and realised two binary packages, one for
> globus and one for accessgrid. These packages are availabled at :
> http://people.vislab.usyd.edu.au/~joseph/index.html . The globus one
> works well (seems to me) but the AccessGrid has a few troubles when I
> try to run VenueClient.py . The problems come from bad links to library.
> I have for example :
> "Traceback (most recent call last):
>   File "/usr/bin/VenueClient.py", line 28, in ?
>     from AccessGrid.Toolkit import WXGUIApplication
>   File "/usr/lib/python2.3/site-packages/AccessGrid/Toolkit.py", line
> 22, in ?
>     from AccessGrid.Security import CertificateManager
>   File
> "/usr/lib/python2.3/site-packages/AccessGrid/Security/CertificateManager.py",
> line 51, in ?
>     from AccessGrid import Utilities
>   File "/usr/lib/python2.3/site-packages/AccessGrid/Utilities.py", line
> 35, in ?
>     from AccessGrid import Platform
>   File
> "/usr/lib/python2.3/site-packages/AccessGrid/Platform/__init__.py", line
> 59, in ?
>     from AccessGrid.Platform.unix import Config as Config
>   File
> "/usr/lib/python2.3/site-packages/AccessGrid/Platform/unix/Config.py",
> line 21, in ?
>     from pyGlobus import security
>   File "/usr/lib/python2.3/site-packages/pyGlobus/security.py", line 11,
> in ?
>     from pyGlobus import gssc
> ImportError: libglobus_gss_assist_gcc32pthr.so.0: cannot open shared
> object file: No such file or directory"
> A "find / -name libglobus_gss_assist_gcc32pthr.so.0" gives me :
> /usr/lib/gpt/lib/libglobus_gss_assist_gcc32pthr.so.0
> To solve this trouble on my own pc, I have just made some symbolic links
> in usr/lib/ . I could do this too in the package but I don't find it
> very "clean", so I will look for another solution.
> If you have a working idea I would gladly accept it !
> Moreover, on the pc where I have done all the required symbolic links, I
> still don't have AG2.2 really running because of a few configuration
> problems (more below). So a few more tricks may be needed before having
> AG2.2 working !
> BTW, I have a few more questions :
> - why is there a pyGlobus.spec in the AccessGrid/packaging/linux/rpm ?
> It doesn't seem to be used, so ?
> - In the dist folder generated after building from source, there a
> ShareApplications folder. Looking at the accessgrid.spec.in file I have
> realised that some files of this folder are not used, like
> SharePresentation.zip. Is it ok ? Do these files have any interest or
> can I just ignore them in my package?
> - In the AccessGrid rpm binary from www.accessgrid.org, there are some
> files and folders added in /usr/bin/python2.2/site-packages.
> However, after having build it from the source on my Debian, these same
> files are to be installed in the python2.3/site-packages directory. I
> guess it's because I use python2.3 on my pc. So I think it means
> python2.3 is compulsory, is it right ? I think I will add it as a new
> dependency for the package. The other way around is either to make a
> postinstall script to check the current version of python or to build AG
> each time... BTW, does it never cause some troubles to just have the
> site-packages installed in the python2.2 folder ? Because it has caused
> some at least to me...
> - In the rpm binary for AccessGrid from www.accessgrid.org, no spec file
> seems to be present (or at least it doesn't appear, when using alien, as
> it does with other rpm packages). Is it really the case ? Why is the
> /tmp /AccessGrid-postinstall file not generated, executed and then
> erased as in AccessGrid.spec.in the AccessGrid/packaging/linux/rpm ? Do
> I have to do it in my own package ?
> - on my working version of AG2.2 I had noticed that there was a warning
> or error (I don't remenber) because of soappy. So I've tried to solve
> this trouble by installing python-soappy (version 0.11.3-0.1) package
> but in fact this installation failed because of some python file in
> python2.3/site-packages/AccessGrid and python2.3/site-packages/pyGlobus.
> I didn't manage to solve these problems and so I have formatted this pc
> to reinstall everything. I would like to know if it's a known issue or
> if I should investigate it more closely, because it could be a conflict
> between AG2.2 and python-soappy packages...
> That's all for the time ! Feel free to comment.
> Cheers,
>  Joseph
