[AG-TECH] ag2.2: pig vs. node proper
    Joshua M. Brown
    jmb10 at uark.edu
    Wed Jun 16 09:39:03 CDT 2004
While i most certainly do appreciate the answer, it was not quite what i
was after. i am aware that AG can be spread across multiple machines (and
that physical machine configurations don't matter so much as long as all
AG software components are running somewhere and can find each other).
What i am after is a system level break-out of the software components:
which python script is doing what, specifically in the multi-machine
configurations.
Thank you.
Joshua M. Brown
CSCE Senior
University of Arkansas
Desktop Unix Support Team
Computing Services, UofA
-----BEGIN PGP PUBLIC KEY BLOCK-----
Version: GnuPG v1.2.4 (GNU/Linux)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=4gVj
-----END PGP PUBLIC KEY BLOCK-----
On Wed, 16 Jun 2004, Osland, CD (Chris)  wrote:
> I'm replying to this before reading all subsequent mail, but can't
> see any replies if the Subject: lines are consistent.
> To the very best of my knowledge, the 'room node' scenario does not
> mandate how many computers you use - different people have used
> 4 (the fourth being the control one for the echo canceller), 3
> (as you noted), 2 (possibly display in one, everything else in the
> other) and 1 (all in the one box).  We have room nodes in both 3
> computer and 1 computer systems.
> Cheers
> Chris
> ____________________________________________________________________
> Chris Osland                                               Office tel: +44
> (0) 1235 446565
> Digital Media and Access Grid                          Medialab tel: +44 (0)
> 1235 446459
> BIT Department                                     Access Grid room tel: +44
> (0) 1235 445666
> e-mail:   C.D.Osland at rl.ac.uk                                       Fax: +44
> (0) 1235 445597
> CLRC Rutherford Appleton Laboratory (Bldg. R18)
> Chilton, DIDCOT, Oxon OX11 0QX, UK
> [The contents of this email are confidential and are for the use of the
> intended recipient only.
> If you are not the intended recipient do not take any action on it or show
> it to anyone else,
> but return this email to the sender and delete your copy of it.]
> > -----Original Message-----
> > From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> > Behalf Of Joshua M. Brown
> > Sent: 15 June 2004 15:40
> > To: ag-tech
> > Subject: [AG-TECH] ag2.2: pig vs. node proper
> > Okay folks,
> > i'm just wanting to solidify some things in my head real
> > quick. With AG
> > 2.2, if you start the VenueClient.py with the --personalNode
> > and -d flags,
> > you get, well a PIG (complete with its own video services
> > (consumer/producer) and its own audio services)) correct? Ah, the
> > services running after being setup, of course.
> > Okay, now on a node proper (room node, i've heard. We're
> > running an old
> > ag1.x room node now), you would have the AudioService.py
> > running on one
> > machine, VideoService.py running on another (both linux of
> > whatever flavor
> > you're inclined to use) and the final piece, VenueClient.py on the
> > "display machine". Is this a correct over-simplification?
> > Again, i'm just
> > making sure i get a solid mental picture of system layout wrt to the
> > scripts.
> > i am aware of the network and port issues that are related
> > with both types
> > of node; just clarifying the diffs.
> > Have i gotten things correctly? Please let me know if this is not the
> > case, we'll be upgrading soon.
> > Thanks folks! :)
> > Joshua M. Brown
> > CSCE Senior
> > =4gVj
