[AG-TECH] 2.2 stability?  Anyone gotten it to run?
    Brian Corrie
    bcorrie at sfu.ca
    Tue Jun 15 16:49:17 CDT 2004
Hi Randy,
This may or may not help. I was able to get 2.2 running on my laptop and
connect to a 2.1.2 venue server fine. The one trick I needed to do was
to remove the AccessGrid folder in the C:\Documents and
Settings\bcorrie\Application Data\
Having this folder with 2.1.2 stuff in it seemed to confuse things and
removing 2.1.2 does not clear this out. Note that you will want to grab
your cert stuff out of that folder before you remove it 8-)
Before I removed this folder I had real trouble getting things to work.
After removing it and doing a reinstall it seemed to work much better...
I didn't stress test much but I could connect to venues and the services
started up properly. By the way, this was with the beta release, not the
current release...
Cheers,
Brian
Randy Groves wrote:
> I realize that this iteration changed a lot of the underlying code, so
> I'm guessing that it's going to take a while for things to settle down.
> I have been attempting, on a laptop, and on my home machine, to get a
> test situation running, so I can at least see what the new features
> are.  After multiple attempts, I have yet to get to any where near what
> I had running on 2.1.2.  I will be attempting this some more - I haven't
> given up, but it is getting bloody frustrating.  I will undoubtedly be
> filling up Bugzilla at the same time.
> So far, I've been attempting to install both a venue server and a client
> on machines that have unpredictable connections to the network and to
> DNS services, and I suspect that some of my problems stem from this.
> How much dependency on a live network connection and access to DNS is
> there for this to work?  Shouldn't I be able to install all this on a
> disconnected laptop?  This doesn't seem to be the case.  I do seem to
> remember that I did NOT have these types of problems with 2.1.2.
> I should add that all of the attempts so far to install the final of 2.2
> have been on Windows XP.
> The video consumer and producer services on XP seem to be much more
> unstable or non-existant than in 2.1.2.  I have yet to get a consumer to
> show up, and attempts to install a producer with a Logitech Quickcam
> (which worked great with 2.1.2), have resulted in hung clients and
> reboots necessary when I couldn't kill the client.  The only service
> which seems to come up dependably is the RAT.
> If anyone has any hints - and I know that this is general - I don't have
> my laptop at this time - I'd sure like to hear them.
> Perhaps I should wait for 2.2.1?
> -randy
