[AG-TECH] Certs issue (perhaps!)
    Joshua M. Brown
    jmb10 at uark.edu
    Wed Jun  9 09:05:14 CDT 2004
Okay, i'm in now. Looks like it was just in the queue, but had me worried.
i'm sure i'll have some more issues, but that one is okay now! Thank you,
and disregard that last message now!
j
Joshua M. Brown
CSCE Senior
University of Arkansas
Desktop Unix Support Team
Computing Services, UofA
-----BEGIN PGP PUBLIC KEY BLOCK-----
Version: GnuPG v1.2.4 (GNU/Linux)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=4gVj
-----END PGP PUBLIC KEY BLOCK-----
On Wed, 9 Jun 2004, Joshua M. Brown wrote:
> Hey folks,
> I've been trying to set up an all RH 7.3 PIG and am having some issues
> with getting my certs authorized. The install is RH 7.3 followed only by
> an install of yum and the packages it wanted to install when given the
> "upgrade" command.
> Then the rpm's from AG (version 2.2) and wxPython rpm linked from the AG
> 2.2 software page.
> I've not done much of anything else with it. No firewall or anything;
> multicast is known-good. v4l and oss drivers are installed and working
> correctly.
> Here is the url of a text file containing the "script" captured output
> when I run the VenueClient and then attempt to check on two certs I had
> applied for yesterday at 6.30am and 7.30am (CST).
> http://ajax.uark.edu/ag/ag_2_2_venueclient_cert_error_debug.txt
> The reason for my concern is that I'd setup a node at home on my own
> machine, requested a cert and received that cert in extremely short order.
> Can someone take a peek at that output and help out? Just in case the above
> link was mistyped, the index is here:
> Thank you very much for your help!
> Joshua M. Brown
> CSCE Senior
