[AG-TECH] Problems while installing AGkt2.2 from source on a Debian
    Joseph
    joseph at cs.usyd.edu.au
    Tue Jun  8 02:08:50 CDT 2004
Hi
I've progressed and solve a few troubles (lack of a few packages mainly)
but for what is still wrong in the log I don't know what to do (even if I
keep trying). Now gpt3.0.1 compiles without trouble (BTW : thanks Steve).
However, does pyGlobus require all of its modules to be built ?
For the time, I have (cf log in info3.tar) :
"Built the following packages:
util
ftpClient
ftpControl
gassCopy
gassTransfer
io
security
Failed to build the following packages due to missing dependencies:
gassCache
gassServerEZ
myProxy
gramClient
rlsClient
xio"
The two others troubles I identify for the time are the problems with
src/crypto and a new ImportError ("ImportError:
libglobus_gss_assist_gcc32pthr.so.0: cannot open shared object file: No
such file or directory", line 1033 of the log).
There is still the point of the missing globus-sh-tools-vars.sh file I add
to copy.
I've also attached the package I add to install until now, if never it can
help someone !
It's all for today, I want fill anymore your mail boxes !
Cheers,
  Joseph
On Tue, 08 Jun 2004 12:28:42 +1000, Joseph <joseph at cs.usyd.edu.au> wrote:
> Hi all
> Looking at the log I have realised that a file called
> globus-sh-tools-vars.sh was missing. I have tried to reinstall  GPT3.0.1
> and Globus Toolkit 3.0.2 but it didn't solve anything. This installation
> was ok except for that :
> build_gpt ====> building support/Digest-MD5-2.20
> /usr/bin/ld: cannot find -lgdbm
> collect2 : ld returned 1 exit status.
> So I look at another computer were I had installed AGtk2.1.2 long ago
> and found the required globus-sh-tools-vars.sh file. Then I put this
> file in the required repertory. It's still not a success for the whole
> construction but there are some improvements, so I attach you
> "info2.tar" with the output of the building and the content of dist_* .
> I continue to work on it.
> BTW, did one of you manage to install AG2.2 on a Debian ?
> Cheers,
>   Joseph
> On Mon, 07 Jun 2004 19:38:03 +1000, Joseph <joseph at cs.usyd.edu.au> wrote:
>> Hello
>> I've sent the requested information directly to Tom and the two others
>> Debian packagers. It's too big to go on the mailing list I think. So if
>> someone is interested, just let me know.
>> Thanks again for your help
>> Cheers,
>> 	Joseph
>> On Mon, 07 Jun 2004 01:53:13 -0500, Thomas D. Uram <turam at mcs.anl.gov>
>> wrote:
>>> Hi Joseph:
>>> For some of the problems you've run into, we'll have to see more
>>> detail to try to help. Could you create a log of the build using
>>> 'script' or something similar, and send the entire build log?  It will
>>> be long, so you might want to send it to ag-mcs at mcs.anl.gov instead of
>>> the ag-tech list; please also include at least the other Debian
>>> packagers (<Jason Hill> jahill at scl.ameslab.gov, dgolden at cp.dias.ie),
>>> too, so they can help if possible.
>>> It's not clear to me from the error output alone why ssl.h is not
>>> being found during the openssl build.  Maybe the reason for this, too,
>>> will be more clear from the more detailed log result.  Please also
>>> send details about what directories have been created in the
>>> timestamped dist directory.
>>> As for rpms:  I expect that for debian the result will debian
>>> packages, not rpms.  The details of creating these packages will
>>> likely be captured in a packaging/linux/debian/BuildPackage.py
>>> script.  I don't know about packaging for debian, so unfortunately
>>> can't help much there.   I can say that the script will likey perform
>>> many of the same tasks as the rpm/BuildPackage.py script.
>>> Thanks again for your work packaging for debian.
>>> Tom
>>> Joseph wrote:
>>>> Hello
>>>> As I need to install AGtk2.2 on a Debian, I've worked from the source
>>>> tarball. To know how to do, I've followed the instructions gently
>>>> given by Thomas D. Uram for the beta version in a doc called
>>>> AG-Linux-Build-HOWTO.rtf (which is quite big so I don't attach it to
>>>> this mail).
>>>> However, when I execute python BuildSnapshot.py --no-check-out
>>>> --sourcedir=/sourcedir in the ccessGrid/packaging directory, I have
>>>> some troubles during the script.
>>>> Firstly, there are a lot of errors in the files in the src/crypto
>>>> directory.
>>>> Then, a failure happens because of an "ImportError: No module named
>>>> pyGlobus".
>>>> Finally, of course, there is a problem with the rpm construction.
>>>> However, the script produces an
>>>> AccessGrid-2.2-Snapshot-date_hour.tar.gz and creates a dist-date_hour
>>>> repertory. I don't have, though, a AccessGrid-2.2-date_hour.tar.gz,
>>>> the binary file.
>>>> BTW, the error output is pasted at the end of this mail. I didn't
>>>> paste the standard output since it's too big.
>>>> I didn't try to solve the firt trouble, because it's some parse
>>>> errors and stuff like this (so trouble with the code itself most
>>>> probably) and it didn't seem to be important for the time.
>>>> I've tried to solve the second point. In the
>>>> AG-Linux-Build-HOWTO.rtf, there was no mention of pyGlobus, but I
>>>> thought it might finally be needed. So I went to pyGlobus website and
>>>> ... found there is no version of pyGlobus for the GlobusToolkit 3.0.2
>>>> (the one used in the AG-Linux-Build-HOWTO.rtf).
>>>> I've tried with pyGlobus for Globus2.4 then 3.2 but it wasn't a
>>>> success (for the 2.4 one it's because I have no repertory for Globus,
>>>> since Globus3.0.2's install doesn't create one, for the other one the
>>>> installation went ok but the AccessGrid intall still fails). I also
>>>> set the PYTHONPATH but without success.
>>>> So I don't know what to do. I have also noticed that some pyGlobus
>>>> files and repertories are made during the installation of AccessGrid
>>>> by the installation script itself, so I wonder if there is a trouble
>>>> during the installation...
>>>> For the rpm, AccessGrid-2.2-Snapshot-date_hour.src.tar.gz and the
>>>> dist-date_hour repertory, I don't know what to do with them in order
>>>> to install AccessGrid. For sure, I don't want some rpm but some
>>>> binary or an installation from the source (to be able to do some
>>>> *.deb for the debian packaging system).
>>>> However, I found nothing close to a binary or an installation script
>>>> in the AccessGrid-2.2-Snapshot-date_hour.src.tar.gz and the
>>>> dist-date_hour repertory. I don't neither have the binary tar.gz
>>>> file, so I don't know what to do to install AccessGrid.
>>>> I hope you don't mind my questions and you will be able to help me !
>>>> BTW, I'm quite new to linux and linux packaging, so I may lack some
>>>> basic knowledges, sorry.
>>>> Cheers,
>>>>      Joseph
>>>> ps : the error output :
>>>> sys:1: DeprecationWarning: Non-ASCII character '\xc3' in file
>>>> setup.py on line 87, but no encoding declared; see
>>>> http://www.python.org/
>>>> peps/pep-0263.html for details
>>>> In file included from src/crypto/crypto.h:17,
>>>>                  from src/crypto/pkcs7.c:12:
>>>> src/crypto/x509.h:17:25: openssl/ssl.h: No such file or directory
>>>> src/crypto/x509.h:27: error: parse error before "X509"
>>>> src/crypto/x509.h:27: warning: no semicolon at end of struct or union
>>>> src/crypto/x509.h:29: error: parse error before '}' token
>>>> src/crypto/x509.h:29: warning: type defaults to `int' in declaration
>>>> of `crypto_X509Obj'
>>>> src/crypto/x509.h:29: warning: data definition has no type or storage
>>>> class
>>>> In file included from src/crypto/crypto.h:18,
>>>> src/crypto/x509name.h:22:25: openssl/ssl.h: No such file or directory
>>>> src/crypto/x509name.h:32: error: parse error before "X509_NAME"
>>>> src/crypto/x509name.h:32: warning: no semicolon at end of struct or
>>>> union
>>>> src/crypto/x509name.h:35: error: parse error before '}' token
>>>> src/crypto/x509name.h:35: warning: type defaults to `int' in
>>>> declaration of `crypto_X509NameObj'
>>>> src/crypto/x509name.h:35: warning: data definition has no type or
>>>> storage class
>>>> In file included from src/crypto/crypto.h:19,
>>>> src/crypto/x509store.h:15:25: openssl/ssl.h: No such file or directory
>>>> src/crypto/x509store.h:25: error: parse error before "X509_STORE"
>>>> src/crypto/x509store.h:25: warning: no semicolon at end of struct or
>>>> union
>>>> src/crypto/x509store.h:27: error: parse error before '}' token
>>>> src/crypto/x509store.h:27: warning: type defaults to `int' in
>>>> declaration of `crypto_X509StoreObj'
>>>> src/crypto/x509store.h:27: warning: data definition has no type or
>>>> storage class
>>>> In file included from src/crypto/crypto.h:20,
>>>> src/crypto/x509req.h:15:25: openssl/ssl.h: No such file or directory
>>>> src/crypto/x509req.h:25: error: parse error before "X509_REQ"
>>>> src/crypto/x509req.h:25: warning: no semicolon at end of struct or
>>>> union
>>>> src/crypto/x509req.h:27: error: parse error before '}' token
>>>> src/crypto/x509req.h:27: warning: type defaults to `int' in
>>>> declaration of `crypto_X509ReqObj'
>>>> src/crypto/x509req.h:27: warning: data definition has no type or
>>>> storage class
>>>> In file included from src/crypto/crypto.h:21,
>>>> src/crypto/pkey.h:22: error: parse error before "EVP_PKEY"
>>>> src/crypto/pkey.h:22: warning: no semicolon at end of struct or union
>>>> src/crypto/pkey.h:24: error: parse error before '}' token
>>>> src/crypto/pkey.h:24: warning: type defaults to `int' in declaration
>>>> of `crypto_PKeyObj'
>>>> src/crypto/pkey.h:24: warning: data definition has no type or storage
>>>> class
>>>> In file included from src/crypto/crypto.h:22,
>>>> src/crypto/x509ext.h:15:25: openssl/ssl.h: No such file or directory
>>>> src/crypto/x509ext.h:16:28: openssl/x509v3.h: No such file or
>>>> directory
>>>> src/crypto/x509ext.h:27: error: parse error before "X509_EXTENSION"
>>>> src/crypto/x509ext.h:27: warning: no semicolon at end of struct or
>>>> union
>>>> src/crypto/x509ext.h:29: error: parse error before '}' token
>>>> src/crypto/x509ext.h:29: warning: type defaults to `int' in
>>>> declaration of `crypto_X509ExtensionObj'
>>>> src/crypto/x509ext.h:29: warning: data definition has no type or
>>>> storage class
>>>> In file included from src/crypto/crypto.h:23,
>>>> src/crypto/pkcs7.h:15:27: openssl/pkcs7.h: No such file or directory
>>>> src/crypto/pkcs7.h:25: error: parse error before "PKCS7"
>>>> src/crypto/pkcs7.h:25: warning: no semicolon at end of struct or union
>>>> src/crypto/pkcs7.h:27: error: parse error before '}' token
>>>> src/crypto/pkcs7.h:27: warning: type defaults to `int' in declaration
>>>> of `crypto_PKCS7Obj'
>>>> src/crypto/pkcs7.h:27: warning: data definition has no type or
>>>> storage class
>>>> In file included from src/crypto/crypto.h:24,
>>>> src/crypto/pkcs12.h:14:28: openssl/pkcs12.h: No such file or directory
>>>> src/crypto/pkcs12.h:15:26: openssl/asn1.h: No such file or directory
>>>> In file included from src/crypto/crypto.h:25,
>>>> src/util.h:17:25: openssl/err.h: No such file or directory
>>>> In file included from src/crypto/pkcs7.c:12:
>>>> src/crypto/crypto.h:70: error: parse error before '*' token
>>>> src/crypto/crypto.h:70: warning: type defaults to `int' in
>>>> declaration of `crypto_X509_New'
>>>> src/crypto/crypto.h:70: warning: function declaration isn't a
>>>> prototype
>>>> src/crypto/crypto.h:70: warning: data definition has no type or
>>>> storage class
>>>> src/crypto/crypto.h:71: error: parse error before '*' token
>>>> src/crypto/crypto.h:71: warning: type defaults to `int' in
>>>> declaration of `crypto_X509Name_New'
>>>> src/crypto/crypto.h:71: warning: function declaration isn't a
>>>> prototype
>>>> src/crypto/crypto.h:71: warning: data definition has no type or
>>>> storage class
>>>> src/crypto/crypto.h:72: error: parse error before '*' token
>>>> src/crypto/crypto.h:72: warning: type defaults to `int' in
>>>> declaration of `crypto_X509Req_New'
>>>> src/crypto/crypto.h:72: warning: function declaration isn't a
>>>> prototype
>>>> src/crypto/crypto.h:72: warning: data definition has no type or
>>>> storage class
>>>> src/crypto/crypto.h:73: error: parse error before '*' token
>>>> src/crypto/crypto.h:73: warning: type defaults to `int' in
>>>> declaration of `crypto_X509Store_New'
>>>> src/crypto/crypto.h:73: warning: function declaration isn't a
>>>> prototype
>>>> src/crypto/crypto.h:73: warning: data definition has no type or
>>>> storage class
>>>> src/crypto/crypto.h:74: error: parse error before '*' token
>>>> src/crypto/crypto.h:74: warning: type defaults to `int' in
>>>> declaration of `crypto_PKey_New'
>>>> src/crypto/crypto.h:74: warning: function declaration isn't a
>>>> prototype
>>>> src/crypto/crypto.h:74: warning: data definition has no type or
>>>> storage class
>>>> src/crypto/crypto.h:75: error: parse error before '*' token
>>>> src/crypto/crypto.h:75: warning: type defaults to `int' in
>>>> declaration of `crypto_X509Extension_New'
>>>> src/crypto/crypto.h:75: warning: data definition has no type or
>>>> storage class
>>>> src/crypto/crypto.h:76: error: parse error before '*' token
>>>> src/crypto/crypto.h:76: warning: type defaults to `int' in
>>>> declaration of `crypto_PKCS7_New'
>>>> src/crypto/crypto.h:76: warning: function declaration isn't a
>>>> prototype
>>>> src/crypto/crypto.h:76: warning: data definition has no type or
>>>> storage class
>>>> src/crypto/pkcs7.c:25: error: parse error before '*' token
>>>> src/crypto/pkcs7.c:26: warning: function declaration isn't a prototype
>>>> src/crypto/pkcs7.c: In function `crypto_PKCS7_type_is_signed':
>>>> src/crypto/pkcs7.c:27: error: `args' undeclared (first use in this
>>>> function)
>>>> src/crypto/pkcs7.c:27: error: (Each undeclared identifier is reported
>>>> only once
>>>> src/crypto/pkcs7.c:27: error: for each function it appears in.)
>>>> src/crypto/pkcs7.c:30: warning: implicit declaration of function
>>>> `PKCS7_type_is_signed'
>>>> src/crypto/pkcs7.c:30: error: `self' undeclared (first use in this
>>>> function)
>>>> src/crypto/pkcs7.c: At top level:
>>>> src/crypto/pkcs7.c:45: error: parse error before '*' token
>>>> src/crypto/pkcs7.c:46: warning: function declaration isn't a prototype
>>>> src/crypto/pkcs7.c: In function `crypto_PKCS7_type_is_enveloped':
>>>> src/crypto/pkcs7.c:47: error: `args' undeclared (first use in this
>>>> function)
>>>> src/crypto/pkcs7.c:50: warning: implicit declaration of function
>>>> `PKCS7_type_is_enveloped'
>>>> src/crypto/pkcs7.c:50: error: `self' undeclared (first use in this
>>>> function)
>>>> src/crypto/pkcs7.c:65: error: parse error before '*' token
>>>> src/crypto/pkcs7.c:66: warning: function declaration isn't a prototype
>>>> `crypto_PKCS7_type_is_signedAndEnveloped':
>>>> src/crypto/pkcs7.c:67: error: `args' undeclared (first use in this
>>>> function)
>>>> src/crypto/pkcs7.c:70: warning: implicit declaration of function
>>>> `PKCS7_type_is_signedAndEnveloped'
>>>> src/crypto/pkcs7.c:70: error: `self' undeclared (first use in this
>>>> function)
>>>> src/crypto/pkcs7.c:85: error: parse error before '*' token
>>>> src/crypto/pkcs7.c:86: warning: function declaration isn't a prototype
>>>> src/crypto/pkcs7.c: In function `crypto_PKCS7_type_is_data':
>>>> src/crypto/pkcs7.c:87: error: `args' undeclared (first use in this
>>>> function)
>>>> src/crypto/pkcs7.c:90: warning: implicit declaration of function
>>>> `PKCS7_type_is_data'
>>>> src/crypto/pkcs7.c:90: error: `self' undeclared (first use in this
>>>> function)
>>>> src/crypto/pkcs7.c:105: error: parse error before '*' token
>>>> src/crypto/pkcs7.c:106: warning: function declaration isn't a
>>>> prototype
>>>> src/crypto/pkcs7.c: In function `crypto_PKCS7_get_type_name':
>>>> src/crypto/pkcs7.c:107: error: `args' undeclared (first use in this
>>>> function)
>>>> src/crypto/pkcs7.c:113: warning: implicit declaration of function
>>>> `OBJ_nid2sn'
>>>> `OBJ_obj2nid'
>>>> src/crypto/pkcs7.c:113: error: `self' undeclared (first use in this
>>>> function)
>>>> src/crypto/pkcs7.c:113: warning: passing arg 1 of
>>>> `PyString_FromString' makes pointer from integer without a cast
>>>> src/crypto/pkcs7.c:143: error: parse error before '*' token
>>>> src/crypto/pkcs7.c:144: error: parse error before '*' token
>>>> src/crypto/pkcs7.c:145: warning: return type defaults to `int'
>>>> src/crypto/pkcs7.c:145: warning: function declaration isn't a
>>>> prototype
>>>> src/crypto/pkcs7.c: In function `crypto_PKCS7_New':
>>>> src/crypto/pkcs7.c:146: error: `self' undeclared (first use in this
>>>> function)
>>>> src/crypto/pkcs7.c:148: error: parse error before ')' token
>>>> src/crypto/pkcs7.c:153: error: `pkcs7' undeclared (first use in this
>>>> function)
>>>> src/crypto/pkcs7.c:166: error: parse error before '*' token
>>>> src/crypto/pkcs7.c:167: warning: function declaration isn't a
>>>> prototype
>>>> src/crypto/pkcs7.c: In function `crypto_PKCS7_dealloc':
>>>> src/crypto/pkcs7.c:169: error: `self' undeclared (first use in this
>>>> function)
>>>> src/crypto/pkcs7.c:170: warning: implicit declaration of function
>>>> `PKCS7_free'
>>>> src/crypto/pkcs7.c:184: error: parse error before '*' token
>>>> src/crypto/pkcs7.c:185: warning: function declaration isn't a
>>>> prototype
>>>> src/crypto/pkcs7.c: In function `crypto_PKCS7_getattr':
>>>> src/crypto/pkcs7.c:186: error: `self' undeclared (first use in this
>>>> function)
>>>> src/crypto/pkcs7.c:186: error: `name' undeclared (first use in this
>>>> function)
>>>> src/crypto/pkcs7.c:14: warning: `CVSid' defined but not used
>>>> error: command 'gcc' failed with exit status 1
>>>> of `crypto_X509Obj'
>>>> class
>>>> union
>>>> storage class
>>>> union
>>>> storage class
>>>> union
>>>> storage class
>>>> of `crypto_PKeyObj'
>>>> class
>>>> directory
>>>> union
>>>> storage class
>>>> storage class
>>>> prototype
>>>> storage class
>>>> prototype
>>>> storage class
>>>> prototype
>>>> storage class
>>>> prototype
>>>> storage class
>>>> prototype
>>>> storage class
>>>> storage class
>>>> prototype
>>>> storage class
>>>> function)
>>>> only once
>>>> function)
>>>> function)
>>>> function)
>>>> function)
>>>> function)
>>>> function)
>>>> function)
>>>> prototype
>>>> function)
>>>> `OBJ_nid2sn'
>>>> `OBJ_obj2nid'
>>>> function)
>>>> prototype
>>>> function)
>>>> function)
>>>> prototype
>>>> function)
>>>> `PKCS7_free'
>>>> prototype
>>>> function)
>>>> function)
>>>> Traceback (most recent call last):
>>>>   File "test_dist.py", line 213, in ?
>>>>     for module in map(__import__, modules_to_test):
>>>>   File "/var/tmp/build/AccessGrid/tests/unittest_ClientProfile.py",
>>>> line 20, in ?
>>>>     from AccessGrid.Platform.Config import SystemConfig
>>>>   File
>>>> "/var/tmp/build/dist-20040603_193542/lib/python2.3/site-packages/AccessGrid/Platform/__init__.py",
>>>> line 59, in ?
>>>>     from AccessGrid.Platform.unix import Config as Config
>>>>   File
>>>> "/var/tmp/build/dist-20040603_193542/lib/python2.3/site-packages/AccessGrid/Platform/unix/Config.py",
>>>> line 21, in ?
>>>>     from pyGlobus import security
>>>> ImportError: No module named pyGlobus
>>>> BuildPackage.py:45: RuntimeWarning: tmpnam is a potential security
>>>> risk to your program
>>>>   TmpDir = os.tmpnam()
>>>> rpm: To install rpm packages on Debian systems, use alien. See
>>>> README.Debian.
>>>> error: cannot open Packages index using db3 - No such file or
>>>> directory (2)
>>>> error: cannot open rpm database in /var/lib/rpm
>>>> cp: cannot stat
>>>> `/usr/src/redhat/RPMS/i386/globus-accessgrid-2.4-1.i386.rpm': No such
>>>> file or directory
>>>> tar:
>>>> /usr/src/redhat/SOURCES/AccessGrid-2.2-Snapshot_20040603_193542.tar.gz:
>>>> Cannot open: No such file or directory
>>>> tar: Error is not recoverable: exiting now
>>>> README.Debian.
>>>> directory (2)
>>>> cp: cannot stat
>>>> file or directory
>>>> tar:
Type: application/x-tar
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040608/b8951c46/attachment.tar>
