[AG-TECH] Problems while installing AGkt2.2 from source on a Debian
    Joseph
    joseph at cs.usyd.edu.au
    Mon Jun  7 21:28:42 CDT 2004
Hi all
Looking at the log I have realised that a file called
globus-sh-tools-vars.sh was missing. I have tried to reinstall  GPT3.0.1
and Globus Toolkit 3.0.2 but it didn't solve anything. This installation
was ok except for that :
build_gpt ====> building support/Digest-MD5-2.20
/usr/bin/ld: cannot find -lgdbm
collect2 : ld returned 1 exit status.
So I look at another computer were I had installed AGtk2.1.2 long ago and
found the required globus-sh-tools-vars.sh file. Then I put this file in
the required repertory. It's still not a success for the whole
construction but there are some improvements, so I attach you "info2.tar"
with the output of the building and the content of dist_* . I continue to
work on it.
BTW, did one of you manage to install AG2.2 on a Debian ?
Cheers,
  Joseph
On Mon, 07 Jun 2004 19:38:03 +1000, Joseph <joseph at cs.usyd.edu.au> wrote:
> Hello
> I've sent the requested information directly to Tom and the two others
> Debian packagers. It's too big to go on the mailing list I think. So if
> someone is interested, just let me know.
> Thanks again for your help
> Cheers,
> 	Joseph
> On Mon, 07 Jun 2004 01:53:13 -0500, Thomas D. Uram <turam at mcs.anl.gov>
> wrote:
>> Hi Joseph:
>> For some of the problems you've run into, we'll have to see more detail
>> to try to help. Could you create a log of the build using 'script' or
>> something similar, and send the entire build log?  It will be long, so
>> you might want to send it to ag-mcs at mcs.anl.gov instead of the ag-tech
>> list; please also include at least the other Debian packagers (<Jason
>> Hill> jahill at scl.ameslab.gov, dgolden at cp.dias.ie), too, so they can
>> help if possible.
>> It's not clear to me from the error output alone why ssl.h is not being
>> found during the openssl build.  Maybe the reason for this, too, will
>> be more clear from the more detailed log result.  Please also send
>> details about what directories have been created in the timestamped
>> dist directory.
>> As for rpms:  I expect that for debian the result will debian packages,
>> not rpms.  The details of creating these packages will likely be
>> captured in a packaging/linux/debian/BuildPackage.py script.  I don't
>> know about packaging for debian, so unfortunately can't help much
>> there.   I can say that the script will likey perform many of the same
>> tasks as the rpm/BuildPackage.py script.
>> Thanks again for your work packaging for debian.
>> Tom
>> Joseph wrote:
>>> Hello
>>> As I need to install AGtk2.2 on a Debian, I've worked from the source
>>> tarball. To know how to do, I've followed the instructions gently
>>> given by Thomas D. Uram for the beta version in a doc called
>>> AG-Linux-Build-HOWTO.rtf (which is quite big so I don't attach it to
>>> this mail).
>>> However, when I execute python BuildSnapshot.py --no-check-out
>>> --sourcedir=/sourcedir in the ccessGrid/packaging directory, I have
>>> some troubles during the script.
>>> Firstly, there are a lot of errors in the files in the src/crypto
>>> directory.
>>> Then, a failure happens because of an "ImportError: No module named
>>> pyGlobus".
>>> Finally, of course, there is a problem with the rpm construction.
>>> However, the script produces an
>>> AccessGrid-2.2-Snapshot-date_hour.tar.gz and creates a dist-date_hour
>>> repertory. I don't have, though, a AccessGrid-2.2-date_hour.tar.gz,
>>> the binary file.
>>> BTW, the error output is pasted at the end of this mail. I didn't
>>> paste the standard output since it's too big.
>>> I didn't try to solve the firt trouble, because it's some parse errors
>>> and stuff like this (so trouble with the code itself most probably)
>>> and it didn't seem to be important for the time.
>>> I've tried to solve the second point. In the AG-Linux-Build-HOWTO.rtf,
>>> there was no mention of pyGlobus, but I thought it might finally be
>>> needed. So I went to pyGlobus website and ... found there is no
>>> version of pyGlobus for the GlobusToolkit 3.0.2 (the one used in the
>>> AG-Linux-Build-HOWTO.rtf).
>>> I've tried with pyGlobus for Globus2.4 then 3.2 but it wasn't a
>>> success (for the 2.4 one it's because I have no repertory for Globus,
>>> since Globus3.0.2's install doesn't create one, for the other one the
>>> installation went ok but the AccessGrid intall still fails). I also
>>> set the PYTHONPATH but without success.
>>> So I don't know what to do. I have also noticed that some pyGlobus
>>> files and repertories are made during the installation of AccessGrid
>>> by the installation script itself, so I wonder if there is a trouble
>>> during the installation...
>>> For the rpm, AccessGrid-2.2-Snapshot-date_hour.src.tar.gz and the
>>> dist-date_hour repertory, I don't know what to do with them in order
>>> to install AccessGrid. For sure, I don't want some rpm but some binary
>>> or an installation from the source (to be able to do some *.deb for
>>> the debian packaging system).
>>> However, I found nothing close to a binary or an installation script
>>> in the AccessGrid-2.2-Snapshot-date_hour.src.tar.gz and the
>>> dist-date_hour repertory. I don't neither have the binary tar.gz file,
>>> so I don't know what to do to install AccessGrid.
>>> I hope you don't mind my questions and you will be able to help me !
>>> BTW, I'm quite new to linux and linux packaging, so I may lack some
>>> basic knowledges, sorry.
>>> Cheers,
>>>      Joseph
>>> ps : the error output :
>>> sys:1: DeprecationWarning: Non-ASCII character '\xc3' in file setup.py
>>> on line 87, but no encoding declared; see http://www.python.org/
>>> peps/pep-0263.html for details
>>> In file included from src/crypto/crypto.h:17,
>>>                  from src/crypto/pkcs7.c:12:
>>> src/crypto/x509.h:17:25: openssl/ssl.h: No such file or directory
>>> src/crypto/x509.h:27: error: parse error before "X509"
>>> src/crypto/x509.h:27: warning: no semicolon at end of struct or union
>>> src/crypto/x509.h:29: error: parse error before '}' token
>>> src/crypto/x509.h:29: warning: type defaults to `int' in declaration
>>> of `crypto_X509Obj'
>>> src/crypto/x509.h:29: warning: data definition has no type or storage
>>> class
>>> In file included from src/crypto/crypto.h:18,
>>> src/crypto/x509name.h:22:25: openssl/ssl.h: No such file or directory
>>> src/crypto/x509name.h:32: error: parse error before "X509_NAME"
>>> src/crypto/x509name.h:32: warning: no semicolon at end of struct or
>>> union
>>> src/crypto/x509name.h:35: error: parse error before '}' token
>>> src/crypto/x509name.h:35: warning: type defaults to `int' in
>>> declaration of `crypto_X509NameObj'
>>> src/crypto/x509name.h:35: warning: data definition has no type or
>>> storage class
>>> In file included from src/crypto/crypto.h:19,
>>> src/crypto/x509store.h:15:25: openssl/ssl.h: No such file or directory
>>> src/crypto/x509store.h:25: error: parse error before "X509_STORE"
>>> src/crypto/x509store.h:25: warning: no semicolon at end of struct or
>>> union
>>> src/crypto/x509store.h:27: error: parse error before '}' token
>>> src/crypto/x509store.h:27: warning: type defaults to `int' in
>>> declaration of `crypto_X509StoreObj'
>>> src/crypto/x509store.h:27: warning: data definition has no type or
>>> storage class
>>> In file included from src/crypto/crypto.h:20,
>>> src/crypto/x509req.h:15:25: openssl/ssl.h: No such file or directory
>>> src/crypto/x509req.h:25: error: parse error before "X509_REQ"
>>> src/crypto/x509req.h:25: warning: no semicolon at end of struct or
>>> union
>>> src/crypto/x509req.h:27: error: parse error before '}' token
>>> src/crypto/x509req.h:27: warning: type defaults to `int' in
>>> declaration of `crypto_X509ReqObj'
>>> src/crypto/x509req.h:27: warning: data definition has no type or
>>> storage class
>>> In file included from src/crypto/crypto.h:21,
>>> src/crypto/pkey.h:22: error: parse error before "EVP_PKEY"
>>> src/crypto/pkey.h:22: warning: no semicolon at end of struct or union
>>> src/crypto/pkey.h:24: error: parse error before '}' token
>>> src/crypto/pkey.h:24: warning: type defaults to `int' in declaration
>>> of `crypto_PKeyObj'
>>> src/crypto/pkey.h:24: warning: data definition has no type or storage
>>> class
>>> In file included from src/crypto/crypto.h:22,
>>> src/crypto/x509ext.h:15:25: openssl/ssl.h: No such file or directory
>>> src/crypto/x509ext.h:16:28: openssl/x509v3.h: No such file or directory
>>> src/crypto/x509ext.h:27: error: parse error before "X509_EXTENSION"
>>> src/crypto/x509ext.h:27: warning: no semicolon at end of struct or
>>> union
>>> src/crypto/x509ext.h:29: error: parse error before '}' token
>>> src/crypto/x509ext.h:29: warning: type defaults to `int' in
>>> declaration of `crypto_X509ExtensionObj'
>>> src/crypto/x509ext.h:29: warning: data definition has no type or
>>> storage class
>>> In file included from src/crypto/crypto.h:23,
>>> src/crypto/pkcs7.h:15:27: openssl/pkcs7.h: No such file or directory
>>> src/crypto/pkcs7.h:25: error: parse error before "PKCS7"
>>> src/crypto/pkcs7.h:25: warning: no semicolon at end of struct or union
>>> src/crypto/pkcs7.h:27: error: parse error before '}' token
>>> src/crypto/pkcs7.h:27: warning: type defaults to `int' in declaration
>>> of `crypto_PKCS7Obj'
>>> src/crypto/pkcs7.h:27: warning: data definition has no type or storage
>>> class
>>> In file included from src/crypto/crypto.h:24,
>>> src/crypto/pkcs12.h:14:28: openssl/pkcs12.h: No such file or directory
>>> src/crypto/pkcs12.h:15:26: openssl/asn1.h: No such file or directory
>>> In file included from src/crypto/crypto.h:25,
>>> src/util.h:17:25: openssl/err.h: No such file or directory
>>> In file included from src/crypto/pkcs7.c:12:
>>> src/crypto/crypto.h:70: error: parse error before '*' token
>>> src/crypto/crypto.h:70: warning: type defaults to `int' in declaration
>>> of `crypto_X509_New'
>>> src/crypto/crypto.h:70: warning: function declaration isn't a prototype
>>> src/crypto/crypto.h:70: warning: data definition has no type or
>>> storage class
>>> src/crypto/crypto.h:71: error: parse error before '*' token
>>> src/crypto/crypto.h:71: warning: type defaults to `int' in declaration
>>> of `crypto_X509Name_New'
>>> src/crypto/crypto.h:71: warning: function declaration isn't a prototype
>>> src/crypto/crypto.h:71: warning: data definition has no type or
>>> storage class
>>> src/crypto/crypto.h:72: error: parse error before '*' token
>>> src/crypto/crypto.h:72: warning: type defaults to `int' in declaration
>>> of `crypto_X509Req_New'
>>> src/crypto/crypto.h:72: warning: function declaration isn't a prototype
>>> src/crypto/crypto.h:72: warning: data definition has no type or
>>> storage class
>>> src/crypto/crypto.h:73: error: parse error before '*' token
>>> src/crypto/crypto.h:73: warning: type defaults to `int' in declaration
>>> of `crypto_X509Store_New'
>>> src/crypto/crypto.h:73: warning: function declaration isn't a prototype
>>> src/crypto/crypto.h:73: warning: data definition has no type or
>>> storage class
>>> src/crypto/crypto.h:74: error: parse error before '*' token
>>> src/crypto/crypto.h:74: warning: type defaults to `int' in declaration
>>> of `crypto_PKey_New'
>>> src/crypto/crypto.h:74: warning: function declaration isn't a prototype
>>> src/crypto/crypto.h:74: warning: data definition has no type or
>>> storage class
>>> src/crypto/crypto.h:75: error: parse error before '*' token
>>> src/crypto/crypto.h:75: warning: type defaults to `int' in declaration
>>> of `crypto_X509Extension_New'
>>> src/crypto/crypto.h:75: warning: data definition has no type or
>>> storage class
>>> src/crypto/crypto.h:76: error: parse error before '*' token
>>> src/crypto/crypto.h:76: warning: type defaults to `int' in declaration
>>> of `crypto_PKCS7_New'
>>> src/crypto/crypto.h:76: warning: function declaration isn't a prototype
>>> src/crypto/crypto.h:76: warning: data definition has no type or
>>> storage class
>>> src/crypto/pkcs7.c:25: error: parse error before '*' token
>>> src/crypto/pkcs7.c:26: warning: function declaration isn't a prototype
>>> src/crypto/pkcs7.c: In function `crypto_PKCS7_type_is_signed':
>>> src/crypto/pkcs7.c:27: error: `args' undeclared (first use in this
>>> function)
>>> src/crypto/pkcs7.c:27: error: (Each undeclared identifier is reported
>>> only once
>>> src/crypto/pkcs7.c:27: error: for each function it appears in.)
>>> src/crypto/pkcs7.c:30: warning: implicit declaration of function
>>> `PKCS7_type_is_signed'
>>> src/crypto/pkcs7.c:30: error: `self' undeclared (first use in this
>>> function)
>>> src/crypto/pkcs7.c: At top level:
>>> src/crypto/pkcs7.c:45: error: parse error before '*' token
>>> src/crypto/pkcs7.c:46: warning: function declaration isn't a prototype
>>> src/crypto/pkcs7.c: In function `crypto_PKCS7_type_is_enveloped':
>>> src/crypto/pkcs7.c:47: error: `args' undeclared (first use in this
>>> function)
>>> src/crypto/pkcs7.c:50: warning: implicit declaration of function
>>> `PKCS7_type_is_enveloped'
>>> src/crypto/pkcs7.c:50: error: `self' undeclared (first use in this
>>> function)
>>> src/crypto/pkcs7.c:65: error: parse error before '*' token
>>> src/crypto/pkcs7.c:66: warning: function declaration isn't a prototype
>>> `crypto_PKCS7_type_is_signedAndEnveloped':
>>> src/crypto/pkcs7.c:67: error: `args' undeclared (first use in this
>>> function)
>>> src/crypto/pkcs7.c:70: warning: implicit declaration of function
>>> `PKCS7_type_is_signedAndEnveloped'
>>> src/crypto/pkcs7.c:70: error: `self' undeclared (first use in this
>>> function)
>>> src/crypto/pkcs7.c:85: error: parse error before '*' token
>>> src/crypto/pkcs7.c:86: warning: function declaration isn't a prototype
>>> src/crypto/pkcs7.c: In function `crypto_PKCS7_type_is_data':
>>> src/crypto/pkcs7.c:87: error: `args' undeclared (first use in this
>>> function)
>>> src/crypto/pkcs7.c:90: warning: implicit declaration of function
>>> `PKCS7_type_is_data'
>>> src/crypto/pkcs7.c:90: error: `self' undeclared (first use in this
>>> function)
>>> src/crypto/pkcs7.c:105: error: parse error before '*' token
>>> src/crypto/pkcs7.c:106: warning: function declaration isn't a prototype
>>> src/crypto/pkcs7.c: In function `crypto_PKCS7_get_type_name':
>>> src/crypto/pkcs7.c:107: error: `args' undeclared (first use in this
>>> function)
>>> src/crypto/pkcs7.c:113: warning: implicit declaration of function
>>> `OBJ_nid2sn'
>>> `OBJ_obj2nid'
>>> src/crypto/pkcs7.c:113: error: `self' undeclared (first use in this
>>> function)
>>> src/crypto/pkcs7.c:113: warning: passing arg 1 of
>>> `PyString_FromString' makes pointer from integer without a cast
>>> src/crypto/pkcs7.c:143: error: parse error before '*' token
>>> src/crypto/pkcs7.c:144: error: parse error before '*' token
>>> src/crypto/pkcs7.c:145: warning: return type defaults to `int'
>>> src/crypto/pkcs7.c:145: warning: function declaration isn't a prototype
>>> src/crypto/pkcs7.c: In function `crypto_PKCS7_New':
>>> src/crypto/pkcs7.c:146: error: `self' undeclared (first use in this
>>> function)
>>> src/crypto/pkcs7.c:148: error: parse error before ')' token
>>> src/crypto/pkcs7.c:153: error: `pkcs7' undeclared (first use in this
>>> function)
>>> src/crypto/pkcs7.c:166: error: parse error before '*' token
>>> src/crypto/pkcs7.c:167: warning: function declaration isn't a prototype
>>> src/crypto/pkcs7.c: In function `crypto_PKCS7_dealloc':
>>> src/crypto/pkcs7.c:169: error: `self' undeclared (first use in this
>>> function)
>>> src/crypto/pkcs7.c:170: warning: implicit declaration of function
>>> `PKCS7_free'
>>> src/crypto/pkcs7.c:184: error: parse error before '*' token
>>> src/crypto/pkcs7.c:185: warning: function declaration isn't a prototype
>>> src/crypto/pkcs7.c: In function `crypto_PKCS7_getattr':
>>> src/crypto/pkcs7.c:186: error: `self' undeclared (first use in this
>>> function)
>>> src/crypto/pkcs7.c:186: error: `name' undeclared (first use in this
>>> function)
>>> src/crypto/pkcs7.c:14: warning: `CVSid' defined but not used
>>> error: command 'gcc' failed with exit status 1
>>> of `crypto_X509Obj'
>>> class
>>> union
>>> storage class
>>> union
>>> storage class
>>> union
>>> storage class
>>> of `crypto_PKeyObj'
>>> class
>>> union
>>> storage class
>>> class
>>> storage class
>>> storage class
>>> storage class
>>> storage class
>>> storage class
>>> storage class
>>> storage class
>>> function)
>>> only once
>>> function)
>>> function)
>>> function)
>>> function)
>>> function)
>>> function)
>>> function)
>>> function)
>>> `OBJ_nid2sn'
>>> `OBJ_obj2nid'
>>> function)
>>> function)
>>> function)
>>> function)
>>> `PKCS7_free'
>>> function)
>>> function)
>>> Traceback (most recent call last):
>>>   File "test_dist.py", line 213, in ?
>>>     for module in map(__import__, modules_to_test):
>>>   File "/var/tmp/build/AccessGrid/tests/unittest_ClientProfile.py",
>>> line 20, in ?
>>>     from AccessGrid.Platform.Config import SystemConfig
>>>   File
>>> "/var/tmp/build/dist-20040603_193542/lib/python2.3/site-packages/AccessGrid/Platform/__init__.py",
>>> line 59, in ?
>>>     from AccessGrid.Platform.unix import Config as Config
>>>   File
>>> "/var/tmp/build/dist-20040603_193542/lib/python2.3/site-packages/AccessGrid/Platform/unix/Config.py",
>>> line 21, in ?
>>>     from pyGlobus import security
>>> ImportError: No module named pyGlobus
>>> BuildPackage.py:45: RuntimeWarning: tmpnam is a potential security
>>> risk to your program
>>>   TmpDir = os.tmpnam()
>>> rpm: To install rpm packages on Debian systems, use alien. See
>>> README.Debian.
>>> error: cannot open Packages index using db3 - No such file or
>>> directory (2)
>>> error: cannot open rpm database in /var/lib/rpm
>>> cp: cannot stat
>>> `/usr/src/redhat/RPMS/i386/globus-accessgrid-2.4-1.i386.rpm': No such
>>> file or directory
>>> tar:
>>> /usr/src/redhat/SOURCES/AccessGrid-2.2-Snapshot_20040603_193542.tar.gz:
>>> Cannot open: No such file or directory
>>> tar: Error is not recoverable: exiting now
>>> README.Debian.
>>> directory (2)
>>> cp: cannot stat
>>> file or directory
>>> tar:
Type: application/x-tar
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040608/f065b4b5/attachment.tar>
