[AG-TECH] 2 intstances vic.exe
    Mike Elmore
    mwelmore at lbl.gov
    Mon Jun  7 12:47:44 CDT 2004
Siraj,
I thought I had tried this configuration.  I configured my node again with only
the
Video Service and I can now see and send video.  However, I don't know how to
point to
the videoservice.zip with windows.  I think that is done with the node
configuration.
Thank you,
Mike
"Sabihuddin, Siraj" wrote:
> I had the same problem when I tried using both the video consumer and
> producer services...each service starts up its own instance of vic.  Instead
> try using only the Video service "VideoService.zip" that comes with AG 2.2 -
> this version should implement both the consumer and producer in one vic
> instance.
> Siraj
> Student Programmer
> Information Security Group, Institute for Information Technology
> National Research Council (NRC), Ottawa, Canada
> Email: Siraj.Sabihuddin at nrc-cnrc.gc.ca,
> WWW - NRC: http://iit-iti.nrc-cnrc.gc.ca
> > -----Original Message-----
> > From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> > Behalf Of Mike Elmore
> > Sent: Friday, June 04, 2004 1:10 PM
> > Cc: ag-tech at mcs.anl.gov
> > Subject: [AG-TECH] 2 intstances vic.exe
> > Hello,
> > I have installed 2.2 on a laptop with xp and I am able to go
> > into the rooms.  I
> > still haven't verified the audio.  When I started the venue
> > client (after two
> > installs) I had video consumer installed in the node.  In
> > order to send my video
> > I had to add video producer or video service to the available
> > services.  They
> > appeared to function identically.  Now, I have two instances
> > of vic.exe running
> > and two windows.  1)video and 2)a window with the room name.
> > The problem is that
> > when I go into a room with a lot of videos, my cpu usage is
> > always at or near
> > 100%, which makes everything take what seems like forever
> > when I change rooms
> > etc,.  I don't remember this happening in 2.1.2  All I had to
> > do was select the
> > video and select transmit to transmit my video.
> > Thanks,
> > Mike
> > Michael Miller wrote:
> > > Would this apply to linux as well?
> > > MYK
> > > At 11:35 AM 6/2/2004, you wrote:
> > > >At 10:45 AM 6/2/2004, Frank Sweetser wrote:
> > > >>I just removed AG 2.1.2 from my laptop, and then
> > installed AG 2.2.  I've had
> > > >>two issues so far
> > > >>         - The GLOBUS_HOSTNAME environmental variable was
> > still set to an
> > > >>           old hostname.  Previously, when the venue
> > client started up, it
> > > >>           would detect that GLOBUS_HOSTNAME wasn't set
> > to a hostname that
> > > >>           was valid for one of the interfaces and bring
> > up a dialoge box
> > > >>           to properly set it.  Now, though, various bits
> > and pieces just
> > > >>           try to talk to a hostname that doesn't map to
> > any of the local
> > > >>           interfaces, and isn't even up.
> > > >The new code detects the hostname to be used, *unless*
> > GLOBUS_HOSTNAME is
> > > >set.  The philosophy is that if the autodetection does not
> > work properly,
> > > >we're probably in an environment where the autodetection
> > couldn't work
> > > >(for instance, we're behind a NAT).
> > > >Unfortunately, this leads us to the problem you're seeing.
> > Probably the
> > > >best thing to do is to go to the environment control panel
> > and remove the
> > > >definition of GLOBUS_HOSTNAME to allow the autodetection
> > to go ahead.
> > > >--bob
> > > Thanx,
> > > Michael Miller
> > > System Engineer
> > > Visualization Technology Support
> > > Computing and Data Management
> > > National Center for Supercomputing Applications
> > > University of Illinois - UC
> > > 217-649-0747
> > > "If you're clear in your vision and trust the people in
> > your team with
> > > clear objectives, they will invariably do their best to
> > achieve everything
> > > desired, and usually deliver everything you could have
> > hoped for and even
> > > more." -Paul Debevec
Type: text/x-vcard
Desc: Card for Mike Elmore
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040607/e6adac80/attachment.vcf>
