[AG-TECH] 2 intstances vic.exe
    Mike Elmore
    mwelmore at lbl.gov
    Fri Jun  4 12:10:28 CDT 2004
Hello,
I have installed 2.2 on a laptop with xp and I am able to go into the rooms.  I
still haven't verified the audio.  When I started the venue client (after two
installs) I had video consumer installed in the node.  In order to send my video
I had to add video producer or video service to the available services.  They
appeared to function identically.  Now, I have two instances of vic.exe running
and two windows.  1)video and 2)a window with the room name.  The problem is that
when I go into a room with a lot of videos, my cpu usage is always at or near
100%, which makes everything take what seems like forever when I change rooms
etc,.  I don't remember this happening in 2.1.2  All I had to do was select the
video and select transmit to transmit my video.
Mike
Michael Miller wrote:
> Would this apply to linux as well?
> MYK
> At 11:35 AM 6/2/2004, you wrote:
> >At 10:45 AM 6/2/2004, Frank Sweetser wrote:
> >>I just removed AG 2.1.2 from my laptop, and then installed AG 2.2.  I've had
> >>two issues so far
> >>         - The GLOBUS_HOSTNAME environmental variable was still set to an
> >>           old hostname.  Previously, when the venue client started up, it
> >>           would detect that GLOBUS_HOSTNAME wasn't set to a hostname that
> >>           was valid for one of the interfaces and bring up a dialoge box
> >>           to properly set it.  Now, though, various bits and pieces just
> >>           try to talk to a hostname that doesn't map to any of the local
> >>           interfaces, and isn't even up.
> >The new code detects the hostname to be used, *unless* GLOBUS_HOSTNAME is
> >set.  The philosophy is that if the autodetection does not work properly,
> >we're probably in an environment where the autodetection couldn't work
> >(for instance, we're behind a NAT).
> >Unfortunately, this leads us to the problem you're seeing. Probably the
> >best thing to do is to go to the environment control panel and remove the
> >definition of GLOBUS_HOSTNAME to allow the autodetection to go ahead.
> >--bob
> Thanx,
> Michael Miller
> System Engineer
> Visualization Technology Support
> Computing and Data Management
> National Center for Supercomputing Applications
> University of Illinois - UC
> 217-649-0747
> "If you're clear in your vision and trust the people in your team with
> clear objectives, they will invariably do their best to achieve everything
> desired, and usually deliver everything you could have hoped for and even
> more." -Paul Debevec
Type: text/x-vcard
Desc: Card for Mike Elmore
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040604/51059aa2/attachment.vcf>
