[AG-TECH] Stale GLOBUS_HOSTNAME not updated
    Frank Sweetser
    fs at WPI.EDU
    Wed Jun  2 13:09:38 CDT 2004
On Wed, Jun 02, 2004 at 11:35:54AM -0500, Robert Olson wrote:
> The new code detects the hostname to be used, *unless* GLOBUS_HOSTNAME is
> set.  The philosophy is that if the autodetection does not work properly,
> we're probably in an environment where the autodetection couldn't work (for
> instance, we're behind a NAT).
> Unfortunately, this leads us to the problem you're seeing. Probably the
> best thing to do is to go to the environment control panel and remove the
> definition of GLOBUS_HOSTNAME to allow the autodetection to go ahead.
Ah!  Removing the GLOBUS_HOSTNAME variable seems to have cleared up both
problems.  Thanks!
Frank Sweetser fs at wpi.edu
WPI Network Engineer
GPG fingerprint = 6174 1257 129E 0D21 D8D4  E8A3 8E39 29E3 E2E8 8CEC
