[AG-TECH] Trouble with VenueClient on AG2.1.2 (was : Certificate)
    Joseph
    joseph at cs.usyd.edu.au
    Wed Jun  2 22:19:05 CDT 2004
Hi
I'm still looking for a solution to my segmentation fault problem after
while requesting a new certificate.
I've looked at the code of VenueClient.py and I've realised that it comes
 from the line :
xext = crypto.X509Extension(name, critical, value)
in the
/usr/lib/python2.3/site-packages/AccessGrid/CertificateRepository.py file
(around line 604, as I've modified the file I can't say exactly which
line).
After this line comes the segmentation fault. I've found too, with a grep
X509Extension, that the only matches are in the binary files
./python2.3/site-packages/OpenSSL_AG/SSL.so and
./python2.3/site-packages/OpenSSL_AG/crypto.so. BTW, I have installed
pyOpenSSL_AG0.5.1 from the AccessGrid download page of AGtk2.1.2 .
Origin of the call of X509Extension :
The xext = crypto.X509Extension(...) line is in fact a part of :
def CreateCertificateRequest(self, nameEntries, passphraseCB, keyType =
KEYTYPE_RSA, bits = 1024, messageDigest = "md5", extensions = None).
This methode is in turn called by :
self.parent.createIdentityCertCB(str(self.name), str(self.email),
str(self.domain),str(self.password),pinfo[0],pinfo[1],pinfo[2])
This line is in the CertificateRequestTool.py file and is part of def
Validate(Self), around line 1000.
Once again, this instruction is called from :
page.Validate()
of def ChangingPage(self, event), around line 164 of
CertificateRequestTool.py.
I hope all this stuff might help you to resolve my trouble. If there is no
hope on your side (I mean on AG development team) please let me know too !
BTW, the VenueClient.log is the same as in the precedent mail (see below).
Thanks
	Joseph
On Wed, 02 Jun 2004 16:11:53 +1000, Joseph <joseph at cs.usyd.edu.au> wrote:
> Hi all
> I have a trouble with VenueClient.py on AG2.1.2. I have installed it on
> a Debian, using a Debian package for wxPython and the src.rpm on
> AccessGrid website. After a few fix everything seemed to be properly
> installed.
> As I don't have any certificate for the time, when I launch
> VenueClient.py (as a normal user), a window appears to help me asking
> for a new certificate. I do everything as ask then I click on "Ok". Then
> the program closes and I see in my terminal "Segmentation fault".
> Chris Willing has told me to check in
> /home/joseph/.AccessGrid/certRepo/requests/ if something appears, but
> it's not the case.
> I have also seen (thanks to the mailing list) that there is a
> VenueClient.log (fully paste at the end of this mail). Only one line is,
> I find, particularly interesting :
> 06/01/04 21:23:28 16384 AG.CertificateRequestTool
> CertificateRequestTool.py:159 DEBUG ChangingPage: From
> AccessGrid.CertificateRequestTool.SubmitReqWindow to <type 'NoneType'>
> I don't know if it's normal.
> Otherwise, the log finishs on :
> 06/01/04 21:23:28 16384 AG.CertificateManagerWXGUI
> CertificateManagerWXGUI.py:444 DEBUG Proxy enabled: 1 value:
> www-cache.usyd.edu.au:8080
> so there is no obvious trouble during the process.
> BTW, apart from this problem, if I start the VenueClient without the
> personnal node services, all the menus and actions work...
> So, if you have any clue on how to make it work, please let me know.
> Cheers,
>        Joseph
> ps: VenueClient.log (the clock isn't on the right time) :
> 06/01/04 21:22:55 16384 AG.DataStore DataStore.py:1615 DEBUG Creating
> thread 0
> 06/01/04 21:22:55 16384 AG.DataStore DataStore.py:1620 DEBUG Starting
> thread 0
> 06/01/04 21:22:55 16384 AG.DataStore DataStore.py:1622 DEBUG Waiting
> thread 0
> 06/01/04 21:22:55 65541 AG.DataStore DataStore.py:1628 DEBUG Worker 0
> starting
> 06/01/04 21:22:55 16384 AG.DataStore DataStore.py:1625 DEBUG Done
> creating workers
> 06/01/04 21:22:55 16384 AG.DataStore DataStore.py:415 DEBUG Reading
> persisted data from:
> /home/joseph/.AccessGrid/personalDataStore/DataStore.dat
> 06/01/04 21:22:55 16384 AG.toolkit Toolkit.py:54 DEBUG userConfigDir:
> 06/01/04 21:22:55 16384 AG.CertificateManager CertificateManager.py:247
> DEBUG Opened repository /home/joseph/.AccessGrid/certRepo
> 06/01/04 21:22:55 16384 AG.CertificateManager CertificateManager.py:963
> ERROR No identity certs found
> 06/01/04 21:22:55 16384 AG.CertificateManager CertificateManager.py:659
> DEBUG Unlink /home/joseph/.AccessGrid/trustedCACerts/42864e48.0
> DEBUG Unlink
> /home/joseph/.AccessGrid/trustedCACerts/42864e48.signing_policy
> DEBUG Unlink /home/joseph/.AccessGrid/trustedCACerts/45cc9e80.0
> DEBUG Unlink
> /home/joseph/.AccessGrid/trustedCACerts/45cc9e80.signing_policy
> 06/01/04 21:22:55 16384 AG.CertificateRequestTool
> CertificateRequestTool.py:62 DEBUG __init__:Start Certificate Request
> Wizard
> CertificateRequestTool.py:76 DEBUG __init__:Set the initial order of the
> pages
> CertificateRequestTool.py:90 DEBUG __init__:Handle arguments for
> certificate type
> CertificateRequestTool.py:115 DEBUG __init__:Create the pages
> CertificateRequestTool.py:120 DEBUG __init__:Run the wizard
> 06/01/04 21:22:57 16384 AG.CertificateRequestTool
> AccessGrid.CertificateRequestTool.IntroWindow to
> AccessGrid.CertificateRequestTool.IdentityCertWindow
> CertificateRequestTool.py:166 DEBUG ChangingPage:Values are correct
> 06/01/04 21:23:16 16384 AG.CertificateRequestTool
> AccessGrid.CertificateRequestTool.IdentityCertWindow to
> CertificateManagerWXGUI.py:443 DEBUG CreateCertificateRequestCB:Create a
> certificate request
