[AG-TECH] Trouble with VenueClient on AG2.1.2 (was : Certificate)
    Joseph
    joseph at cs.usyd.edu.au
    Wed Jun  2 01:11:53 CDT 2004
Hi all
I have a trouble with VenueClient.py on AG2.1.2. I have installed it on a
Debian, using a Debian package for wxPython and the src.rpm on AccessGrid
website. After a few fix everything seemed to be properly installed.
As I don't have any certificate for the time, when I launch VenueClient.py
(as a normal user), a window appears to help me asking for a new
certificate. I do everything as ask then I click on "Ok". Then the program
closes and I see in my terminal "Segmentation fault".
Chris Willing has told me to check in
/home/joseph/.AccessGrid/certRepo/requests/ if something appears, but it's
not the case.
I have also seen (thanks to the mailing list) that there is a
VenueClient.log (fully paste at the end of this mail). Only one line is, I
find, particularly interesting :
06/01/04 21:23:28 16384 AG.CertificateRequestTool
CertificateRequestTool.py:159 DEBUG ChangingPage: From
AccessGrid.CertificateRequestTool.SubmitReqWindow to <type 'NoneType'>
I don't know if it's normal.
Otherwise, the log finishs on :
06/01/04 21:23:28 16384 AG.CertificateManagerWXGUI
CertificateManagerWXGUI.py:444 DEBUG Proxy enabled: 1 value:
www-cache.usyd.edu.au:8080
so there is no obvious trouble during the process.
BTW, apart from this problem, if I start the VenueClient without the
personnal node services, all the menus and actions work...
So, if you have any clue on how to make it work, please let me know.
Cheers,
       Joseph
ps: VenueClient.log (the clock isn't on the right time) :
06/01/04 21:22:55 16384 AG.DataStore DataStore.py:1615 DEBUG Creating
thread 0
06/01/04 21:22:55 16384 AG.DataStore DataStore.py:1620 DEBUG Starting
thread 0
06/01/04 21:22:55 16384 AG.DataStore DataStore.py:1622 DEBUG Waiting
thread 0
06/01/04 21:22:55 65541 AG.DataStore DataStore.py:1628 DEBUG Worker 0
starting
06/01/04 21:22:55 16384 AG.DataStore DataStore.py:1625 DEBUG Done creating
workers
06/01/04 21:22:55 16384 AG.DataStore DataStore.py:415 DEBUG Reading
persisted data from:
/home/joseph/.AccessGrid/personalDataStore/DataStore.dat
06/01/04 21:22:55 16384 AG.toolkit Toolkit.py:54 DEBUG userConfigDir:
06/01/04 21:22:55 16384 AG.CertificateManager CertificateManager.py:247
DEBUG Opened repository /home/joseph/.AccessGrid/certRepo
06/01/04 21:22:55 16384 AG.CertificateManager CertificateManager.py:963
ERROR No identity certs found
06/01/04 21:22:55 16384 AG.CertificateManager CertificateManager.py:659
DEBUG Unlink /home/joseph/.AccessGrid/trustedCACerts/42864e48.0
DEBUG Unlink
/home/joseph/.AccessGrid/trustedCACerts/42864e48.signing_policy
DEBUG Unlink /home/joseph/.AccessGrid/trustedCACerts/45cc9e80.0
DEBUG Unlink
/home/joseph/.AccessGrid/trustedCACerts/45cc9e80.signing_policy
06/01/04 21:22:55 16384 AG.CertificateRequestTool
CertificateRequestTool.py:62 DEBUG __init__:Start Certificate Request
Wizard
CertificateRequestTool.py:76 DEBUG __init__:Set the initial order of the
pages
CertificateRequestTool.py:90 DEBUG __init__:Handle arguments for
certificate type
CertificateRequestTool.py:115 DEBUG __init__:Create the pages
CertificateRequestTool.py:120 DEBUG __init__:Run the wizard
06/01/04 21:22:57 16384 AG.CertificateRequestTool
AccessGrid.CertificateRequestTool.IntroWindow to
AccessGrid.CertificateRequestTool.IdentityCertWindow
CertificateRequestTool.py:166 DEBUG ChangingPage:Values are correct
06/01/04 21:23:16 16384 AG.CertificateRequestTool
AccessGrid.CertificateRequestTool.IdentityCertWindow to
CertificateManagerWXGUI.py:443 DEBUG CreateCertificateRequestCB:Create a
certificate request
