[AG-TECH] Stale GLOBUS_HOSTNAME not updated
Michael Miller
mimiller at ncsa.uiuc.edu
Wed Jun 2 11:44:19 CDT 2004
Would this apply to linux as well?
MYK
At 11:35 AM 6/2/2004, you wrote:
>At 10:45 AM 6/2/2004, Frank Sweetser wrote:
>>I just removed AG 2.1.2 from my laptop, and then installed AG 2.2. I've had
>>two issues so far
>> - The GLOBUS_HOSTNAME environmental variable was still set to an
>> old hostname. Previously, when the venue client started up, it
>> would detect that GLOBUS_HOSTNAME wasn't set to a hostname that
>> was valid for one of the interfaces and bring up a dialoge box
>> to properly set it. Now, though, various bits and pieces just
>> try to talk to a hostname that doesn't map to any of the local
>> interfaces, and isn't even up.
>The new code detects the hostname to be used, *unless* GLOBUS_HOSTNAME is
>set. The philosophy is that if the autodetection does not work properly,
>we're probably in an environment where the autodetection couldn't work
>(for instance, we're behind a NAT).
>Unfortunately, this leads us to the problem you're seeing. Probably the
>best thing to do is to go to the environment control panel and remove the
>definition of GLOBUS_HOSTNAME to allow the autodetection to go ahead.
>--bob
Thanx,
Michael Miller
System Engineer
Visualization Technology Support
Computing and Data Management
National Center for Supercomputing Applications
University of Illinois - UC
217-649-0747
"If you're clear in your vision and trust the people in your team with
clear objectives, they will invariably do their best to achieve everything
desired, and usually deliver everything you could have hoped for and even
more." -Paul Debevec
